Usher pre-amp woes... - Page 2 - diyAudio
Old 24th September 2004, 04:22 AM   #11
Illusus is offline Illusus  Canada
Illusus's Avatar
Bill, that just makes too much sense!! thanks
Fighting the program since 1976.
Old 24th September 2004, 04:28 AM   #12
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by Upupa Epops
or never switch off .
That is actually a very good advice. Why would you like to switch off the preamp anyway?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 24th September 2004, 04:53 AM   #13
Illusus's Avatar
to conserve! just kidding, I know this thing doesn't draw enough current to concern me. I like things to work properly before I hack them up. 'Just that I bought it and it doesn't function up to my expectations is a peave.
Update- the problem seems to stem from the tone controls. When powering down with the tone defeat switch off (tone controls active) the offset is much lower, it peaks for a second at 430mV instead of the 5V I was getting with the tone controls disabled.
Old 24th September 2004, 11:04 PM   #14
Illusus's Avatar
I wonder if I just bypassed the tone control stage all together if this thing would work properly. I don't like the sound as much with the tone controls active, it sounds noticeably more detailed with the tone controls disabled.
In the tone control section there are a couple ic's (look like op amps) witht the numbers scratched off them , I wonder what they are.
Old 25th September 2004, 12:20 AM   #15
It is little bit like in story about fox and vine bunch : " I don't like it, 'cos is acid ! " and changing cause to result . Why do you have preamp with tone controls, if they lower transpareny ?
Old 25th September 2004, 03:04 AM   #16
Illusus's Avatar
Because it came that way. I bought this unit out of curiosity, and, for the most part, am pleasantly surprised. My other preamps are a Dynaco PAS2 which I tore all control circuits out of and a passive pre.
I'll bypass the tone control circuitry as soon as I get a chance, if the problem at power down remains it'll be easier to track down.
SP/DIF Woes mark4man Digital Source 3 2nd April 2010 04:04 AM
CFP Oscillation woes ian_elvar Solid State 0 29th July 2008 09:55 PM
WTB 3 qty Usher T-9950 & Usher Qty 1 - 8845 markmelheim Swap Meet 1 17th May 2006 11:15 PM
Pre-amp woes mluckey Solid State 1 31st October 2003 08:20 PM
aleph woes sriegel Pass Labs 7 20th January 2002 06:22 PM
Copyright ©1999-2017 diyAudio
