diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   MJE350 orcad model (http://www.diyaudio.com/forums/solid-state/41286-mje350-orcad-model.html)
djdamix 21st September 2004 08:34 AM
MJE350 orcad model
I'm looking for a MJE350 orcad model (it's for my VAS stage). If somebody could send me this model.
Thanks.
Have a nice day
David
JensRasmussen 21st September 2004 08:38 AM
Try looking at www.onsemi.com
\Jens
djdamix 21st September 2004 08:43 AM
thanks, but
I've tried it, but none of the format available seems to work with orcad. The message is always something like "library not valid"
David
Hoffmeyer 21st September 2004 12:53 PM
Hi djdamix.
My guess is that You're using an older version of PSpice/Orcad, not compatible with the newer library format !
Try an upgrade ;o)
Konrad 21st September 2004 05:42 PM
Modell is on this page : http://www.onsemi.com/site/support/l...outputSize=50&
http://www.onsemi.com/pub/Collateral/MJE350.LIB
use Mje 350.lib save to a folder/place.
This is not the prefered way, but will work: edit somthing you newer use, or make new component is prefered:
place like mje 42 in ure drawing. right click and press edit spice modell. Then all parameters for the mje42 coms up.
open the mje350.lib with like notepad compare and edit the mje42. afterwards save the edited mje 42 as prefered in prefered...
there ia a lot of ways to do editing in orcad. orcad video demos is also somwere on the www.
good luck
edit: if you'r using separate spice lib remember to add it to the libraries where you edit pspice profile.
djdamix 22nd September 2004 06:49 AM
ok, I'll try that, thanks a lot !
Have a nice day
David
Konrad 22nd September 2004 08:01 AM
Have you tryed downloading models from the orcad site?
Bouth .lib and .olb 's are available, So why bother just download and replace/add ur libs ?
http://www.orcadpcb.com/pspice/models.asp?bc=F
djdamix 22nd September 2004 08:10 AM
ok, thanks a lot for the link , my lib where not up to date ...
Copyright 1999-2017 diyAudio
