diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   question about input stage of this amp (http://www.diyaudio.com/forums/solid-state/4127-question-about-input-stage-amp.html)
hugobross 19th June 2002 09:28 PM
2 Attachment(s)
Hi, I just found this interesting schematic and I just wondered if my theory about how this amp works is right or not.
I like this schematic because of it's input stage with two current sources.
If I understand it correctly Q9 en Q4 act like current sources, so when no input connected there will flow following biasing current:
I(bias) = (4.7V - 0.7V)/1820 * Hfe(Q4)
When the input signal (Vi) increases, Vb(Q3) will decrease and
Ic(Q3) will increase. The current through the biasing circuit doesn't change so the current through the base of Q5 will increase.
Q7 and Q8 give the signal a phase shift of 180 degrees that we need for the negative feedback.
When Vi decreases, Ic(Q3) will decrease and Ib(Q6) will raise, etc...
I'm just wondering if C9 is placed over there to prevent that the bias voltage will drop when Ic(Q3) decreases or has this capacitor another function??
thanks,
HB.
Nelson Pass 19th June 2002 10:49 PM
Looks like a Dan Meyer Tiger Amp.
Correction: Tigers had dual diff inputs.
The schematic style is Audio Magazine.
Works as you surmise.
The cap C9 is just to keep the high frequency
impedance of the bias network low for wider
drive bandwidth.
hugobross 20th June 2002 09:05 AM
2 Attachment(s)
Thanks Nelson, I'm glad to hear that!!!
Now, I've still have these questions about the included output stage:
What's the function of D12 and D13?? To protect the transistors against inductive loads?? Is it really necessary to use them?
And what's the exact reason of the 22ohm resistor and the 3H inductor? I calculated the impedance of it:
Z=(R*jwL) / (R+jwL) w=2*pi*f
Z= (jwRL)(R-jwL) / (R+jwL)(R-jwL)
Z= (wRL + jwRL) / (R + (wL))
so it seems that it acts like a low pass filter, is that correct?
Thanks,
HB.
HarryHaller 20th June 2002 09:20 AM
They increase the amp stability into cable capacitance and other capacitive loads. The resistor damps LC resonance. Very common circuit for output of audio power amps.
H.H.
peranders 20th June 2002 10:31 AM
Thanks,
HB.
The diodes are wise to have and correct they take care of currents from inductive load when you abruptly shut off the current. The current through the load (speakers) must go somewhere. If you don't have them you can kill the output stage. (note that MOSFET's have these diodes by nature, not exactly as normal silicone diodes but they do the job pretty good)
The output filter isolates the amp from capacitive load and/or difficult speakers (the same thing more or less) and the value isn't very critical. 0,5-3 H (15-20 turns normal wire, diam. 10-15 mm) in parallel with 5-22 ohm.
The filter can also block HF picked up from speaker and the cable.
hugobross 20th June 2002 11:49 AM
Hey thanks for helping me!!
These were the last big things I didn't understand correctly about power amps. Soon, I'll start to design my first own designed amp (not too heavy and quiete simple of course).
Thanks,
HB.
Nelson Pass 20th June 2002 07:24 PM
The diodes protect against flyback voltages, and are a
hangover from the old days when V/I limiters were
used for protection. They don't hurt, though, so we leave
them on in case we encounter something really crude for
a load. Mosfet amps don't need them, so you only see them
on Bipolars.
The output coil and resistor are similarly hangovers from the
old days. They were in the original RCA manual, and most
designers use them because monkey-see-monkey-do.
I have never seen a case where they stabilized an unstable
amp, nor where their absence caused instability, and so I
don't use them.
By contrast, the RCA network to ground on the output is
standard and useful for feedback amps. Again, I don't tend
to use them, but I don't usually have enough feedback to
worry about.
BrianL 20th June 2002 11:05 PM
The schematic style is Popular Electronics, not Audio.
The design is a Dan Meyer / SWTP design. Pre-Tiger amps didn't have dual complementary diff amp inputs.
The SS1122/SS1123 transistors seemed to be
a Motorola "special" for SWTP. At lease I never
found them in regular databooks. I always thought
that "SS" stood for "Southwest Special".
The CFP-like outputs with the gain-of-2 setup
was another Dan Meyer "signature" feature.
For the newbies around here, SWTP stands for
Soutwest Technical Prouducts Corp. which did
various kits in the late 60s (?) and early 70s.
If I recall correctly, they were based in San
Antonio, TX. (which geographically is hard
to call southwest, but that's a different topic)
djk 21st June 2002 10:27 AM
The 'Little Tiger', ca 1969, was about 25W with the plastic TO127 outputs. The 215 was the 'Tiger .01" front end on the same output stage, ca 1972. The other circuit fragment is a scan from the RCA Power Handbook.
hugobross 21st June 2002 02:29 PM
the first amp is by popular electronics 1975
the second application is by RCA, final release in 1972
I found them here: http://www.hilberink.nl/amps/amps.htm
Copyright 1999-2017 diyAudio
