#11 |
The input buffers on the 44 and later 34s certainly do enable a myriad of input sensitivities and impedances, they even made microphone input modules for the 44 but are the buffers just masking a problem with or easing the PCB layout as well as complicating the signal path ??
http://www.dc-daylight.ltd.uk/Valve-...D-34-Mods.html ACD... Note QUADs deliberate use of asymetric supplies used on the QUAD34 to give a small +ve offset at the op-amp outputs. Did you account for this when you removed all the capacitors ? Also you quote response to dc after the mod, did you throw out the tilt/bass controls just so you could see your speaker cones waft back and forth once a week when driven from a VLF generator ! More seriously if your QUAD 34 was an early one with single op-amps did you measure the cross talk at any time ?? |
#12 |
Well I'm back after a short break and no reply, could it be the Dutchman has flown ??
Blue |
| Convert 110v to 230v input ? | istari knight | Digital Line Level | 6 | 1st January 2009 07:41 PM |
| current bias j-fet input 2sk170 ,2sj74 at input stage | YUTK | Solid State | 11 | 2nd June 2005 03:34 AM |
| Want to convert amplifier output to input level | rkc7 | Everything Else | 1 | 16th May 2004 10:19 AM |
| Transformer at input of SOZ to convert unbalanced->balanced? | psarin | Pass Labs | 29 | 29th December 2003 05:13 AM |
| How to convert Unbalance -> Balance Input ? | Minh | Solid State | 21 | 19th September 2002 11:09 AM |
| Page generated in 0.05304 seconds (80.26% PHP - 19.74% MySQL) with 10 queries |
