Old 17th September 2004, 03:16 PM   #1
Default 4A bias on a IRFP240n???
Is it ok to run a IRFP240n at 24vdc and 4A bias? Is this too close to max dissapation?
Should I run 2 of them in parallel??
They are connected as source follower into a 1:1 output transformer.
Thanks!!
It is not you... you are it.
Old 17th September 2004, 03:27 PM   #2
You are dissipating 100 Watts into a single device, which is pushing it to the limit. If you have a very large heat sink (that will not get more than 50C hot), and it is anodized so you can mount the IRFP without insulation, then it is possible.
Else i would use 2 in parallel.
Cheers
Lars
Old 17th September 2004, 04:04 PM   #3
Default i keep frying them...
hmm... i seem to keep frying them... dunno why.
bias is fine...
perhaps I should fuse them.... duh!
or run them lower current during testing.
Old 17th September 2004, 04:09 PM   #4
Did you mount them with a MICA insulator?
Old 17th September 2004, 06:15 PM   #5
The one and only
Nelson Pass's Avatar
At 100 watts you can expect to lose the regularly. I try
not to exceed 50 watts.
Old 17th September 2004, 07:10 PM   #6
sajti is online now sajti  Hungary
I used IRF520 with 30W dissipation. It was not so reliable. I guess to use the IRFP240N up to some 50-60W. If You need more, try to use IRFP260N, which is rated to 300W@25C...
sajti
Old 17th September 2004, 07:20 PM   #7
Audiogeek: Are you sure it's IRFP240N ??
This device doesn't seem to exist.
Old 19th September 2004, 01:09 AM   #8
it was an IR part... obselete now i think.
so if I wanted a device that would handle 80W.... recommendations?
Old 19th September 2004, 08:24 AM   #9
Try to get TO-3 device. That can handle more power, and accept higher temperature. Or try IRFP260N, which is rated to 300W at 25C. Mount them without insulator, and insulate the whole heatsink. And You have to use separated heatsink for each device! Fan cooling is good solution for it.
sajti
Old 19th September 2004, 09:42 AM   #10
AudioGeek: OK, my suggestion is to use the IRFP250N, and mount it on a black anodized surface without insulator (but with thermal grease). It will withstand easily the 100 Watts of dissipation, if the heat sink stays below 70 C.
IRFP150N will also do nicely. but IRFP250N is the cheapest device.
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 05:26 PM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 01:30 AM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Supressed bias amplifier, automatic variable bias system. destroyer X Solid State 2 20th September 2004 10:24 AM
Page generated in 0.09638 seconds (77.89% PHP - 22.11% MySQL) with 10 queries
