paralel MOS-FETīs HELP - diyAudio
Old 16th September 2004, 11:34 PM   #1
viki is offline viki  Portugal
Default paralel MOS-FETīs HELP
Hello, i built an amplifier using mos fet IRF 540 and 9540, can I paralel two IRF 540 and the two 9540 so that can dissipate more power and to use lower impedances speakers
Or paraleling MOS-FETīs will affect the circuit and sound quality?
Tanks
Old 17th September 2004, 07:56 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
It depends on the design of the amp. The voltage amplifier stage (VAS) must be able to supply enough current to drive the additional MOSFETs. 10mA should be OK as a bare minimum.
Each MOSFET must have a low value (0.22-0.47 ohm) resistor in the source. It is also recommended that the MOSFETs are matched as the Vgs can vary quite a bit.
Do a search for parallel MOSFET and MOSFET matching for more info.
Old 17th September 2004, 09:16 AM   #3
Konrad is offline Konrad  Norway
A while ago i bought a tube of 100, the spread in Vgs on is significant!
Dependent of konfiguration you may need to adjust some compensation network.
like simple cfp and doubling the mosfets driven by a transistor the BC cap ( slow down ) may nead some adj.
Old 17th September 2004, 01:32 PM   #4
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I usually find that International Rectifier TO-247 devices come in a tube of 25. The only thing I know which comes in a tube of 100 are SO-8 opamps. The Hitachi (now Renesas) Lateral MOSFETs come in tubes of 30.
When I do matching -- I find that the distribution of devices along Vgs with Id of 1.000 amp is normal or at worst bimodal. Of course this means that you have devices on the tails of the curve. If you are finding a wide distribution of Vgs you may want to make sure that the time for each test remains constant and that the ambient temperature is the same --
Old 17th September 2004, 01:59 PM   #5
Well i didnt do any statistic calculations.
for clarity : i bougt 100 irf640, 100 irf9640 , in to220, total of "4 tubes".
Can i paralel the 2 opamps in 5532? jondoe Chip Amps 6 17th December 2004 04:53 AM
TDA729X paralel/bridge project StratoFan Chip Amps 42 23rd March 2004 07:01 AM
TDA 7293s paralel ,voltage... B.I.G Chip Amps 0 18th March 2004 08:37 PM
Paralel resistor jan Multi-Way 9 5th September 2003 05:11 AM
Paralel CS8420 & CS8414 A'af Digital Source 10 16th January 2003 02:19 PM
Copyright ©1999-2017 diyAudio
