redesign of leach amp pcb for integrated TO-247 output devices - diyAudio
Old 17th June 2002, 07:42 PM   #1
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default redesign of leach amp pcb for integrated TO-247 output devices
Ever since I finished my leach amp, I have been thinking of ways to improve the design. I have decided to redesign the pcb in order to use TO-3P (TO-247) devices that will be integrated into the pcb, and effectively eliminating a lot of external wiring for the amplifier (12 wires to be exact).
I have the pcb layout mostly worked on paper, and have about half done on the computer. Here are a few pictures of my progress:
http://brian.darg.net/leachamppcb
Feel free to add comments to the pictures in the gallery.
The preliminary board specs will be these:
4" x 6" dimensions (dimensions might approach 3" x 6" if possible)
2 layer pcb
0.093" board thickness
2 oz copper on both sides
soldier mask on both sides
silkscreen on top layer
Preliminary parts list with dimensions:
http://brian.prohosting.com/leachamp.xls
I most likely will use the MJL3281A/MJL1302A (more linear) devices instead of the MJL21193/MJL21194 output devices, but since I currently have some MJL21193/MJL21194 devices, I will use them for prototyping.
Any comments/suggestions on this project would be appreciated. I will update the pictures of my layout, as I near completion. I should finish the layout soon, and get some prototype boards made in august, then if everything works good, get a large batch of production quality boards made for myself and some friends, possibly opening up room for others, but this is a couple of months off, so I will discuss this later.
Brian
Old 26th June 2002, 01:01 AM   #2
BrianGT's Avatar
I have the pcb layout just about done, and have posted the new board layout, also with a component view without the traces, and a parts list.
If anyone is interested in building one of these Leach Amps with the new boards, let me know.
If you want to see pictures of my first leach amp, using the 4.5 boards, go here:
http://brian.darg.net/leachamp-2channel
Brian
Old 26th June 2002, 01:13 AM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default price
Brian what is the price and what is the power out put of a leach amd that you have just made pcbs for..?
i might be interested
j
please email me back thanks
jleaman@kaien.net jleaman@citytel.net
Old 26th June 2002, 01:22 AM   #4
BrianGT's Avatar
It is no different from the normal Leach amp, which outputs around 120w per channel.
I am not getting boards made until August, as I am in France studying for the summer (Georgia Tech has a campus here).
As for the price, I am not sure yet. I am just wondering if there is enough interest for me to order a batch of pcbs. They should cost no more then $50 for a pair including shipping inside the US, if I order a high enough quantity. They will be double sided with soldier mask, silk screen, 2 oz copper, and 0.093" thick board.
Does anyone who has built and modified a leach amp have any suggestions for any modifications to the design?
Brian
Old 26th June 2002, 10:54 AM   #5
Kevinbd is offline Kevinbd  United Kingdom
Default Leach Circuit Diagrams
Hello,
Could anyone point to a link with the Leach schematics. I have heard it is a good amp but have never seen the diagrams.
Kevin
Old 26th June 2002, 11:12 AM   #6
Geoff is offline Geoff  United Kingdom
Kevin
Go to the front page of diyAudio.com. Scroll down to where it says links. Select amplifier projects. Move to page 2. The fifth entry down is entitled "The Leach Amp". Click on this link.
Alternatively, do as the rest of us do and use Google, AltaVista, Lycos or whatever is your preference.
Old 26th June 2002, 11:12 AM   #7
BrianGT's Avatar
Leach Amp webpage:
http://users.ece.gatech.edu/~mleach/lowtim/
Leach Amp circuit diagram (pdf)
http://users.ece.gatech.edu/~mleach/...aphics/ckt.pdf
Brian
Old 27th June 2002, 07:24 PM   #8
Brian you know this site?
http://home.swipnet.se/malman/LeachAmp.html
Watching beginnings of social decay....
Virus - Iron Maiden
Old 30th June 2002, 06:04 PM   #9
BrianGT's Avatar
Yes, but his board was for integrated TO-3 devices. I have a similar goal to his, but I want to use the newer case devices, which are much easier to use with heatsinks.
Comparison of devices:
http://brian.darg.net/leachamppcb/aaj
The metal ones are the old to-3 output devices and the plastic case ones are the TO-247 (also called TO-3P).
By the way, the board design is done:
Brian
Old 1st July 2002, 04:23 AM   #10
EJ is offline EJ
Default does it have to be two-layer board?
It will be difficult for most diyers to make the board by themselves
if it is not single-layer. I think one of reasons why Leach Amp is
so popular is that the board is quite easy to make.
URL Collection of Commercial Single Ended Integrated and Power Amplifier Devices tiefbassuebertr Solid State 11 10th July 2012 10:56 AM
Output Devices ! cloud Pass Labs 11 11th November 2008 12:37 AM
Jens' Leach Boards--6 devices FS gengis Swap Meet 2 13th January 2008 04:17 PM
More Output devices...A75 FBJ Pass Labs 14 19th March 2002 07:18 AM
Leach amp as a integrated amp? supernet Solid State 3 4th February 2002 09:13 PM
Copyright 1999-2017 diyAudio
