redesign of leach amp pcb for integrated TO-247 output devices
Old 1st July 2002, 08:35 AM   #11
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Re: does it have to be two-layer board?
Originally posted by EJ
It will be difficult for most diyers to make the board by themselves if it is not single-layer. I think one of reasons why Leach Amp is so popular is that the board is quite easy to make.
I agree with this, but keeping the design single sided would have limited the design quite a bit. By using double sided, placement can be more controlled, jumper wires eliminated and shorter traces can be used. I have the board currently done, so that I can send the gerber files off to any board manufacturer and have the double sided boards made with a nice silkscreen. If there is enough interest, I will do a large order for other people on this forum to join in. It doesn't cost too much for the boards, if a lot of people join in.
Brian
Old 1st July 2002, 08:43 AM   #12
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
I am in .
Old 1st July 2002, 08:49 AM   #13
BrianGT's Avatar
I will post a new thread when I get a price quote and am ready to order.
Brian
Old 1st July 2002, 02:36 PM   #14
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Thumbs up nice layout! what if ....
Brian:
Your layout really looks good! What's the possibility of adding patterns to use the 2SA1349/2SC3381 monolithic duals in their special wierd package for the dual diff stages in addition to the usual TO-92 package devices currently being used and adding patterns for different voltage gain driver devices (say, the 2SA1210/2SC2912 in the TO-126 package) in addition to the TO-5 package devices currently used? Just to be clear, I'm saying adding patterns (pads, holes, routes, etc.) IN ADDITION to the original Leach selected parts. That way, one could build the original design and experiment/update with more modern parts without tearing up the PCBs.
By the way, I think I'll be looking for six boards :-)
mlloyd1
Old 1st July 2002, 02:51 PM   #15
mlloyd1's Avatar
Default Re: nice layout! what if ....
ooops! forgot to add the device pics!
Originally posted by mlloyd1
Brian:
Your layout really looks good! What's the possibility of adding patterns to use the 2SA1349/2SC3381 ....and adding patterns for .... the 2SA1210/2SC2912 in the TO-126 package....
mlloyd1
Old 3rd July 2002, 03:47 PM   #16
BrianGT's Avatar
Sorry, I cannot add extra pads for these devices, but the existing pads are spaced far enough apart for use of these devices, and the holes are big enough for the leads of your devices.
I have posted a new version of the leach amp pcb at:
http://brian.darg.net/leachamppcb
Revisions include:
- room for larger caps (film and electrolytic) in the input stage
- spacing set for use of terminal blocks for input and output
- added information to silkscreen
- greatly fattened the trace where the output device currents sum up
- widened the board by 0.5" to accomidate the wider trace and the larger caps. This also left room to fit the terminal block for the inputs.
I believe that I have finished the pcb layout. If anyone has any suggestions, let me know.
Thanks a lot to those who have e-mailed me suggestions for board improvement!
Brian
Old 4th July 2002, 09:48 AM   #17
JensRasmussen is offline JensRasmussen  Denmark
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Similar project
Hello there
At the moment I'm making a set of PCB's for the Leach Amp.
The concept is like this:
Small signal board with overything but drivers and output transistors
Output board with driver and output transistors. And an option to put in more output transistors.
This way it's easy to try out different transistors in the output stage without having to assemble severel different sets of PCB's
There is a thread for this.
Old 7th August 2002, 09:38 PM   #18
Default Making prototypes
Hi again
Got my output prototype PCB's done.
Working on the input
\Jens
Old 8th August 2002, 06:34 AM   #19
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Nice looking prototype but is it need for so many output devices (compared to the heatsink)?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 8th August 2002, 06:51 AM   #20
EJ is offline EJ
Talking nice job!
Nice looking board! And it seems to be single sided, making it easy for me to reproduce one by myself. However, why did you put all your components on the copper side? Doesn't this make your soldering difficult for components such as elec.caps?
redesign of leach amp pcb for integrated TO-247 output devicesHide this!Advertise here!
URL Collection of Commercial Single Ended Integrated and Power Amplifier Devices tiefbassuebertr Solid State 11 10th July 2012 09:56 AM
Output Devices ! cloud Pass Labs 11 10th November 2008 11:37 PM
Jens' Leach Boards--6 devices FS gengis Swap Meet 2 13th January 2008 03:17 PM
More Output devices...A75 FBJ Pass Labs 14 19th March 2002 06:18 AM
Leach amp as a integrated amp? supernet Solid State 3 4th February 2002 08:13 PM
