redesign of leach amp pcb for integrated TO-247 output devices - Page 11 - diyAudio
Old 29th October 2003, 09:19 AM   #101
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default More PICS
Hi all,
The thing is alive
I now need to sort out the top and front
\Jens
Old 29th October 2003, 09:20 AM   #102
Default More PICS
The back
Old 29th October 2003, 09:21 AM   #103
Default More PICS
From the top
Old 20th September 2004, 08:56 PM   #104
Hello all,
I have had several requests for my version of the Leach Amp, but lost my original layout some time ago due to a hard disk failure (I will now be making weekly backups).
Anyway I have remade the layout on one board with room for 5 sets of output transistors and 10000uF 100V rail caps. (40mm diameter)
Let me know if anybody is interested in a group order for these, and also if you have any requests regarding the PCB.
The PDF pic contains the layout, witch measures 120xx250 mm
\Jens
Old 21st September 2004, 12:20 PM   #105
arasuk is offline arasuk  India
Send a message via ICQ to arasuk Send a message via AIM to arasuk
Wink modified leach amp
Hi JENs,
Your version of leach amp looks good , can I request you to provide me the pdf files of the leach amp so I can do this amp. (of course this is my dream amp).
1. you have used 5 pairs of Output pairs, what was the purpose, can it increase the power or you have done this to handle loads down to 2ohms.
2. what is the max voltage rail you recommend.
3. can I use 2sa1943 & 2sc5200 pairs.
4. can you provide some details of your modified version.
Arasuk
Old 21st September 2004, 01:11 PM   #106
Hi Arasuk,
I have done this to be able to play into smaller loads and to increase the rail voltages while keeping a decent SOA for the output devices.
So far I have only tested it with +-55V, but Iíll be making tests with +-68V when I get the proto PCBs
YES! And MJL4281/4302
Small signal transistors are BC546/556
Vas and pre driver are MJE340/350
Drivers are MJE15034/15035
Extra decoupling caps on board along with zobel network and fuses.
The rest of the components are more or less the original, I'll be making a BOM later when everything is tested
\Jens
Old 21st September 2004, 02:16 PM   #107
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Looks good!
left lane is for passing, slower traffic keep right please.
Old 21st September 2004, 06:27 PM   #108
Smile Modified leach amp!!
Hi Jens,
Thanks for the reply,
1. I remember Mr.Leach pointing out that +/- 58v is the best possible rail voltage. do you think Increasing it will lead for SOA problem.
2. Then using BC546/556 would not be probably better ???
3. About the short ckt prot what values do you reccomend,and have you tested with these values.
4.Does the "diode array" need to be implemented on the heat sinks??? can I replace them with some To220 type diodes or with an BJT.
thanks
Arasuk
Old 21st September 2004, 06:40 PM   #109
I think he means for the setup with two transistors.
I don't understand what you mean, please explain
I have tested them using +-55V, they need to be recalculated with +-68V!
You must place the diodes on the heatsink!! TO220 diodes could work well, for thermal tracking, not sure how the added cap to heatsink will influence the thing though
\Jens
Old 22nd September 2004, 05:22 PM   #110
acenovelty's Avatar
Sweet! Now how's about boards, docs, price? Except for plate thru, I can make my own 2 sided board. Foil pattern price?
Prosit
URL Collection of Commercial Single Ended Integrated and Power Amplifier Devices tiefbassuebertr Solid State 11 10th July 2012 09:56 AM
Output Devices ! cloud Pass Labs 11 10th November 2008 11:37 PM
Jens' Leach Boards--6 devices FS gengis Swap Meet 2 13th January 2008 03:17 PM
More Output devices...A75 FBJ Pass Labs 14 19th March 2002 06:18 AM
Leach amp as a integrated amp? supernet Solid State 3 4th February 2002 08:13 PM
Copyright ©1999-2017 diyAudio
