Sugden P28
Sugden P28
Old 20th August 2006, 10:52 PM   #11
Michel is offline Michel  Canada
Hello King,
There are not many things that can do this kind of problem in a P28.
If my memory is good there is not even a speaker relay in there which could be the cause.
The only things I can see is a dirty rca connector or the mono/stereo toggle switch that is inside.
A good cleaning with a quality product such as DeoxIT should cure hesitations.
One other thing, sometimes the fuse holders tabs get loose when they have had frequent careless fuse replacements.
I am not even sure it can happen with a P28 but if it is the case, all you have to do is remove the fuse
and press the tabs between your fingers until they nearly touch each other and put the fuse back.
I have seen that fuse holder tabs problem numerous times, especially with the ones that have the beige base.
The best way to avoid excessive stress to the tabs when replacing a fuse is to use a fuse puller.
The only one I recommend for that is the Ideal Industries 34-015.
Good luck!
Michel
Old 21st August 2006, 01:12 PM   #12
mikeks is offline mikeks  United Kingdom
Account Disabled
Default Re: Sugden P28 and P128
Originally posted by Michel
Sugden has always had the extremely bad habit of using capacitors that are too close to the working voltage. They do tend too to put resistors , transistors or zener diodes that radiates heat close to them...........
The other things that go wrong after the capacitors are the BC639 and BC640 drivers which have a little too much on their plate............
Old 21st August 2006, 05:54 PM   #13
King is offline King  Canada
Thank Michel, I will take a look tonight; however, sare there any possibly bad capacitors that might contribute to this problem.
BTW, my P28 has the heatsink at the back of the unit.
Old 22nd August 2006, 01:57 PM   #14
Hi Michel and others, I open up the P28 last night, cleaned the
toggle switch with contact cleaner; and also discovered that indeed one of the 2A fuse holder was loose, so I squeeze the fuse holder with my fingers put the fuse back and now is fuse is tightly seating in place.
Since it was pretty late so I listen to it for may be 20 minutes, and so far no cutting in and out; hope it really resolved that problem.
I also got a reply from Sugden from England; they send me the A28II spec., they said the P28 use the same spec. only it's a power amp.
Stereo: 44 Watts/ch
Bridged: 95 watts
Question: How do you bridge the P28 to 95 watts mono?
Thanks again Michel, really appreciated your input.
King
Toronto, Ontario, Canada
Old 22nd August 2006, 09:45 PM   #15
Oh , Sugden (U.K.) also mentioned that the P28 is Class AB not
Class A; I always thought P28 is Class A !?
Anybody
Old 23rd August 2006, 07:07 AM   #16
R.I.P.
a far as I know the P28 is a high bias ClassAB (maybe a couple of watts of ClassA).
If the sinks look like my P128 they are far too small to support ClassA.
regards Andrew T.
Old 10th March 2008, 06:54 PM   #17
JulianSK is offline JulianSK  Taiwan
Unhappy Sugden P28
Michel,
Would you please send me the P28 schematic?
My P28 (heatsink on the side) went down and appears the fuzzy sound exactly the same as you mentioned in the thread. The fuzzy sound could last fuzzy sound 5 minutes and worked well initially. Now it comes fuzzy sound only without stop.
My technician (he is good at analog but I am more a digital guy) needs a schematic to examine not only capcitors also power transistors to close the two months mightmire on blindly check those components.
AAfter I read your post, we'd like to follow your suggestion to start over the examination of my P28 (capcitors and BC639/640 drivers) to avoid meassurement in the dark.
Old 10th March 2008, 06:54 PM   #18
Question Sugden P28 schematic
Can anyone send me a Sugden P28 schematic?
I am sticky on the fuzzy sound for two months. I really love this power AMP and need to repair its fuzzy sound.
Thnaks
Old 10th March 2008, 07:24 PM   #19
Hi Julian,
To fix a P28 with heatsinks on each side you need the A28B schematic.
Give me your email address and I will send it to you.
There are 5 parts marked by an asterisk on the parts overlay, make sure they are the value shown.
Do not hesitate to contact me if you need more help.
Michel
Old 12th March 2008, 07:16 AM   #20
Default Sugden P28
Michel,
Much appreciated...please send me the schematic to juliansk@ms2.hinet.net and julian.fann@intel.com these two email addresses.
I do love the sound of Sugden so that my concern is those capacitors. I am not sure how much sound quality those capacitors can impact.
My technican (an anlog guy) do concern sound quality by replacing those drivers.
We are guessing if brand of those capacitors and drivers matter on sound quality. How do you think?
I hope my bad English is readable...apology if this makes you confused. I can try to rephrase.
Best regards
Sugden P28Hide this!Advertise here!
Sugden A28 II schématic ? v6us Solid State 15 24th January 2016 03:38 PM
Sugden A28B Sjaak Everything Else 0 15th November 2008 11:51 AM
Need help with Sugden A-51 champybuddy Solid State 3 18th February 2008 04:04 PM
Sugden C51 and P51 tubenut Solid State 3 27th April 2005 08:45 AM
