Old 3rd August 2012, 09:05 AM   #131
AntG is offline AntG  Netherlands
Hi Michel,
If possible could you send me the circuit diagram of the A28II.
<agxaudio(at)hotmail.com>
Last year I asked for some advice about a cracking volume potentiometer the advice to clean it solved the problem, unfortunately the unit has suddenly stopped powering on and all the internal fuses seem fine so maybe with the circuit diagram I can find the fault.
Many thanks
Ant G
Old 27th August 2012, 08:03 AM   #132
lany is offline lany  Denmark
HI fellow Sugden listeners
I would be very pleased if someone could send me scematics for Sugden P28 and A28II?
please send to "lasse at nylanders.dk"
I've bought a secondhand P28 in order to have a bridge setup with my A28II, but the P28 sounds terrible, and the PCB shows signs of burned resistors. All power Transistors have been changed an non of the are the same.
Is it even possible to have the amp restore so i can use it with mu A28?
If not I will try to use it in bi-amp instead any one has experience with this combo?
Hope someone can help me out here!
Old 25th September 2012, 03:50 PM   #133
Hi lany, check your Mailbox
Phil
Old 26th September 2012, 10:07 AM   #134
Hi Phil
I saw your post to Lany and I was hopping you could help me out a with schematic diagram for the A28II if you have it.
A while ago it stopped working and I have put off investigating further apart for a quick visual inspection until I have more information.
It would be most appreciated if you could assist.
Old 26th September 2012, 03:08 PM   #135
Hi Phil
Thanks very much.
kind regards
Antony
Old 27th September 2012, 08:02 AM   #136
Old 27th October 2012, 05:39 PM   #137
thank you Phil
BR
LANY
Old 14th November 2012, 04:57 AM   #138
qewl is offline qewl  Canada
Default Need schematic A28-ll
I am looking for an A28 mkll schematic, could some one please email it to qewl@videotron.ca
Thanks in advance,
Karl
Old 5th February 2013, 06:21 AM   #139
Hello Michel,can you send me schematic for Sugden a28b?Thank you for your time. vpusinskas@yahoo.ie
Old 18th February 2013, 09:13 AM   #140
Hi Michel
Saturday morning my A28 gives a big constant noise to speakers.
A strong DC signal was added to played music.
I immediatly stopped the buzz by switching off the amp.
Your opinion ?
Phil
PS : I'll post pics today
Sugden A28 II schématic ? v6us Solid State 10 12th June 2011 10:36 PM
Sugden A28B Sjaak Everything Else 0 15th November 2008 11:51 AM
Need help with Sugden A-51 champybuddy Solid State 3 18th February 2008 04:04 PM
Sugden C51 and P51 tubenut Solid State 3 27th April 2005 08:45 AM
Copyright ©1999-2013 diyAudio
