Transformer coupled linestage
Old 18th October 2005, 09:57 AM   #11
Panelhead is offline Panelhead
Default Amps
I did run a mono pair of Tamps for a while. The preamp worked great. The low imput impedance of the T amps is no problem. I am now using a My_Reference amp. It is better than the T amps in my system.
The circuit can be found by seaching here for either Tao buffer or Eight Part Harmony. My current board has a 46 ohm resistor on bottom, a 20 ohm pot in series with a 28 ohm resistor inbtween the sa1837. The output is taken off the wiper of the pot.
With a 20 turn pot the dc can be dailed to 0.0 mv. This is plenty low. Those 410 transformers have a dcr of 38 ohms and seem to deal with up to 5 mv dc with no issues. I suspect a few ma will saturate them.
The circuit works great without transformer coupling. Used this circuit for a year without transformer coupling.
Line now has a pair of Cinemag CLM15/15B input transformers also. And the PEC log taper pots mentioned.
I have now built three of these boards. The layouts are getting better each time. This pays off in sound quality.
Good luck in constructing this great little buffer.
George
Transformer coupled linestageHide this!Advertise here!
TX coupled, pentode linestage Bandersnatch Tubes / Valves 14 21st May 2010 04:26 PM
Transformer Coupled Linestage hpn5350 Tubes / Valves 11 27th February 2008 02:11 PM
