#21 |
To sajti : Do you mean, that Halcro amps have not any OL gain ? Do you can miracles with one " stone age " tube and simply follower ? Try to think differently and don't listen only to people who says similar nonsenses
#22 | |
In this amplifier I use IRF530 (SGS), which is quite linear over .5A, but can dissipate only 60W at 25degree. I still try to find higher power device. sajti |
#23 | |
This simple amplifier was big surprise to me. When I start to put it together it was just a play for me. ... Stone age had some advantages: No lawyers, no managers..... sajti |
#24 |
To sajti : Listening is not about belief, it is about correct experiences
#25 |
I see using MOSFETs and tubes in open loop as a bad idea. Triodes are particularly linear provided the right I/V operating range [not as wide as desirable], but MOSFETs suffer from a *strong* square law behavior everywhere and they require lots of feedback to linearize, particularly in case of the 'symetric-square-law' found on all class B or AB MOSFET designs
People likes signal degradation produced in exotic ways. People loves asymetric distortion, transformer saturation, loose bass due to speaker ringing at its Fs/Fc, rolled-off frequency responses and power compression, but I wonder why nobody admits this fact |
#26 |
This is neverending faith, Eva. Some people don't need to know truth, they can listen vizards and hope in miracles
#27 | |
sajti |
#28 |
But a MOSFET follower does not follow the input voltage, it follows [ intput_voltage - Vgs ] and Vgs tends to be proportional to the square root of Id
The 'gain' [transconductance] only determines the Vgs variation for a given Id variation, ie: output impedance [that is not constant but inversely proportional to the square root of instantaneous Id |
#29 |
Eva,
I agree what You wrote. This is why the mosfet sounds better with higher bias. Higher bias means less change on the Vgs, due the higher transconductance. This also means lower distortion too. As I wrote, I will try to apply some feedback with higher gain valve. If there will be news regarding this, I will wrote it! sajti |
#30 |
Hi All,
I think the last exchange pretty much sums things up. -Chris |
| Some noise measurements for LEDs and zener diodes | Christer | Parts | 127 | 25th November 2011 11:47 PM |
| 15V zener diodes | mantisory | Vendor's Bazaar | 0 | 16th November 2007 11:55 PM |
| very ignorant question on zener diodes | jarthel | Parts | 1 | 13th October 2006 01:17 PM |
| Bride of ZEN zener diodes | ding | Pass Labs | 21 | 3rd June 2006 04:31 PM |
| computer amplifier zener diodes overheating? | DoomPixie | Chip Amps | 8 | 14th January 2006 01:23 PM |
