Old 17th June 2002, 03:33 AM   #11
Banned
Default Stinking MOSFETs
I hate them too, man.
Ren
Old 17th June 2002, 04:24 AM   #12
Warp Engineer
On Holiday
AudioFreak's Avatar
For SE Class A output stages MOSFET's are SWEET!
Old 17th June 2002, 08:28 AM   #13
Default Re: What makes an amplifier "bright", "warm", or "neutral"?
Originally posted by JohnS
Which component, components, or circuits make an amplifier "bright", "warm", or "neutral"?
bright - lightly biased Class B/AB stages; some opamps; cheap metal film resistors; some metallised pp caps; most cheap lytics; hf noise or oscillations in circuit adds brittleness
warm - polyester caps; oil filled ones; some class A stages.
Just a few descriptors from experience
Old 17th June 2002, 08:43 AM   #14
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
fmak, are you telling me you like the sound of polyester caps? I've always heard they were the worst poly cap. Sometimes I have to use them due to cost though...
Old 17th June 2002, 09:56 AM   #15
Does anybody know any software which can add some harmonics to the signal ( 2nd or so) to perform the test?
You can try to build a analog octave device.. used for guitar effects.. look at http://www.geofex.com/
gr,
Thijs
Old 17th June 2002, 10:55 AM   #16
Default adding harmonics
Originally posted by Koy
Reading the first post an indea struck me. People say the tonality can depend on amout of upper harmonics ( prevailing even or odd harmonics). Does anybody know any software which can add some harmonics to the signal ( 2nd or so) to perform the test?
I am of the opinion, from my own experience, that it is not as simple as 2nd v's 3rd harmonic. Rather it is the relative distribution of harmonics that is important. Also, there seems to be a strong similarity between the distribution of harmonics in valve amps and class A transistor amps, class B being quite different to these two. This might help to explain why class A are reputed to have a warm "valve sound".
I have done subjective experiments in audio in the past and they are very difficult to design so that they give you unbiased results. The best way to go about it would be to capture some suitable music samples from a CD and then pre-process them using something like Octave running on your PC (free Matlab clone found at www.ocatave.org). If you are not familiar with DSP there is a steep learning curve to using programs like this but they are hugely powerful. You then would need to perform double blind tests using processed and unprocessed versions of the same track and analyse your results later. You have to be very meticulous to avoid biasing the results but if you go for it, I'd love to hear your results.
DocP
Old 17th June 2002, 04:45 PM   #17
No, just that they are warmer than pp
Old 17th June 2002, 05:14 PM   #18
mrfeedback's Avatar
Default The Nature Of The Noise
Distortions spectrums and tiny abberations in static and dynamic frequency response, and source and load dependance, and slew rate limitation.
0.1 dB frequency response ripple is audible and apparent.
Also reaction to noise input.
Noise spectrum input and load noise spectrum can both be modified and substantially alter the percieved sonic character of a system.
Regards, Eric.
Old 17th June 2002, 07:04 PM   #19
Brett's Avatar
<b>What makes an amplifier "bright", "warm", or "neutral"?</b>
Bright: uses thoriated tungsten tubes
Warm: turned on, esp if uses tubes or SS class A
Neutral: beige chassis
Old 17th June 2002, 08:21 PM   #20
Banned
Thumbs up What makes an amplifier
Way to go Brett! Maybe the only honest rational answer possible to such a broad question. All one has to do is design amplifiers for about 10 to 20 years for the real answers to this question. I would not even dare to propose an answer and I don't think anyone else in his right mind would either as there are thousands of things that can effect this highly subjective classification.
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 06:53 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 09:31 PM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 05:33 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Page generated in 0.12236 seconds (80.23% PHP - 19.77% MySQL) with 10 queries
