Old 9th September 2004, 07:51 PM   #1
Johnix is offline Johnix  France
Question Is the Toshiba 2SJ201/2SK1530 pair (Mosfet) suitable for output stage ?
I was wondering...
http://www.schuro.de/Daten/Japanhalbleiter/2SJ201.pdf
http://www.schuro.de/Daten/Japanhalbleiter/2SK1530.pdf
Are they lateral MOSFETs like Hitachi's 2SJ162/2SK1058 ?
Old 12th September 2004, 03:01 PM   #2
MikeB is offline MikeB  Germany
MikeB's Avatar
Yes, they are intended to be used in audiooutputstages !
Old 12th September 2004, 03:51 PM   #3
Audiofanatic's Avatar
Default Re: Is the Toshiba 2SJ201/2SK1530 pair (Mosfet) suitable for output stage ?
Originally posted by Johnix
I was wondering...
They are exelent.
Advantage uses them in there amps.
Best regards,
Audiofanatic ;-)
Be nice to animals.
Old 12th September 2004, 04:02 PM   #4
And how would them sound compared to 2SK1058/2SJ162 ?
Old 12th September 2004, 10:02 PM   #5
Default Sound
The sound is wider and deeper.
Lets say, holographic. That's the best way to explain it.
Audiofanatic
Be nice to animals.
Old 13th September 2004, 02:21 AM   #6
Default 2Sk1530 and 2SJ201 and excellent combination
I have been using the 2Sk1530 and 2SJ201 combination in all my amplifiers for years. They are very fine performers when driven properly. I typically use 6ea 2SK1530 and 6ea 2SJ201 in each channel in a common source configuration.
I have a circuit diagram available of a amplifier I originally designed in 1992 that I used to have on my web site. This is a complex amplifier and not for those who believe totally in the keep it simple methods. It is likely not suitable for those starting out in this hobby. If anyone is interested I can put it back on my web site. I just need a little time to dig out the documentation. I have a limited number of circuit boards and the special power transformer available.
Johannes
Old 13th September 2004, 04:52 AM   #7
Electrons are yellow and more is better!
peranders's Avatar
It's an interesting amp and complex is the word I haven't taken the time to really investigate all cool features but it looks well-done. It would be fun to see a picture of this amp or at least the pcb layout.
I'll upload the schematics for a while at my place (a couple of weeks).
http://www.sjostromaudio.com/alaskan..._power_amp.pdf
http://www.sjostromaudio.com/alaskan...onent_side.pdf
http://www.sjostromaudio.com/alaskan...older_side.pdf
http://www.sjostromaudio.com/alaskan...silkscreen.pdf
/Per-Anders (my first name) or P-A as my friends call me
Old 13th September 2004, 07:03 PM   #8
Default Mosfet Power Amp
PERANDERS I appreciate you making the schematic of one of my MOSFET power amps available on your web site. If desired I can supply the PCB layout for both the amplifier circuit board and the power supply/control circuit board.
It will take me a while longer to redo my own web site before it is useable again.
Johannes
Old 13th September 2004, 08:11 PM   #9
peranders's Avatar
Please send me the layout and maybe a picture and I will upload it. But I will only have links from here... for a while.
Use the email address which I have at my web pages (at the bottom of each page).
Old 15th September 2004, 04:22 PM   #10
Default Re: Sound
Audiofanatic
Ok thanks
2 more questions :
- are they lateral mosfets like 2SK1058/2SJ162
- are they thermally compensed
Designing amp with 2SJ201/2SK1530 Rikard Nilsson Solid State 243 15th September 2010 04:21 PM
Help me... 2sk1530,2sj201 Spice oke55555 Parts 1 26th July 2010 10:52 PM
Matched 2SK1530/2SJ201 ashaw Solid State 9 22nd October 2008 09:56 AM
Help with amp??? LM4702+2SK1530/2SJ201 Dougie085 Solid State 13 1st December 2007 03:25 PM
I've been told Toshiba is discontinuing 2SK1530 & 2SJ201 in US thoriated Solid State 0 14th April 2004 08:04 PM
Page generated in 0.11297 seconds (78.64% PHP - 21.36% MySQL) with 10 queries
