Tivoli Pal battery problem - diyAudio
Old 9th September 2004, 09:50 AM   #1
Unhappy Tivoli Pal battery problem
I just bought a Tivoli Pal radio from ebay.
The problem with this radio is that it can not charge it's internal battery . I checked the battery pack on the back of the unit and did not see any obvious problems. The unit supplies 14.8-15 volts of DC voltage to the battery pack for charging. But the batteries do not charge!
I took a closer look at the battery pack and noticed that something like a big resistor is connected in series between two batteries (of the six). This component has two legs and a metal body for cooling I suspect. It writes KC100oC 250V 5A. Does anyone know what this is? Maybe this is causing the problem. Can I bypass it?
Many thanks
George
Old 9th September 2004, 12:26 PM   #2
This could be a thermoswitch that is in place for safety reasons. If you use an ohmmeter (no charger connected & radio switched off)you'll see if it is interrupted.
Charles
Old 9th September 2004, 12:48 PM   #3
johnnyx is offline johnnyx  United Kingdom
That will be a 5A fuse.
Fuses come in all shapes, some are axial and look like resistors, some have small square plastic packages that look like poly caps, some are round cans and look like electrolytics.
A new engineer started at work, checking a board.
I asked "have you checked the fuses?"
He replied "what fuses?"
Old 9th September 2004, 01:05 PM   #4
Charles,
I will take a look this afternoon.
Old 10th September 2004, 06:05 AM   #5
I checked the thermoswitch and it has zero resistance. I have left the radio on all night but the batteries have not charged. With the battery pack connected to the radio and the radio is on ac power the batteries show a 2.98volt between their output terminals. Any suggestions?
Thanks again
George
Old 10th September 2004, 01:37 PM   #6
I just found out from Tivoli that they have a problem with many Pal batteries. The replacement pack cost 45euros! I have found 8 batteries 1.2v each on ebay for 20$. So I plan to make a battery pack by myself using 6*1.2v AA batteries = 7.2V
The question I have is how to connect the batteries between them to form a pack. The problem is not the orientation of the batteries and their inbetween connections but how does one solder tabs between the batteries. Will my solder gun do? Do I need special equipment. On the battery pack I have I can see that no solder has been used but the tabs have been placed by pressure. I cab see the pressure marks. What shouls I do?
Thanks George
Old 10th September 2004, 09:20 PM   #7
It's a fuse, trust me.
While rechargeable cells are available with welded tags to simplify connecting them together to form a battery, I have successfully soldered short wires between them for the same purpose.
First scratch away some of the plating and make it rough. If you don't do this, the solder blobs and doesn't wet the terminals. Then tin the terminal, after which you can solder the wire. I use an 18W Antex iron, and have successfully soldered to "C" size cells with this method, so you don't need a lot of heat, but more heat will help. The cells seem to tolerate this well.
I connect a Schottky rectifier in reverse parallel with each cell, as recommended in an article from Electronics World. The reason given for this is that cells discharge at different rates, and when one is becoming exhausted, it is reverse - biased by the others. This damages the cell, and is of greater importance the more cells there are.
Hope you find this useful
Old 25th September 2011, 03:01 PM   #8
Thanks again
George
Hi, your post is quite old, but still, Tivoli radios are around the corner!
I had a similar problem with my Tivoli's battery pack and found that one cell showed ~0v (it is easy to remove the pack's plastic cover to gain acces to each cell terminal points). So, I planned to replace only the defective cell with a standard AA/R3 NiMH battery. The most "difficult" part in this operation was the soldering step: just like it is mentionned here by johnnyx, you have to scratch the metal surface before solder the new cell to the metal connectors.
Finally, I used a kind of "rapid fix glue" to glue the new cell to other ones and then replaced the plastic cover and fixed it with scotch rubber. The battery pack was repaired!
However, I face another problem: whenever the battery is charged, the radio won't turn on without the help of the power supply! Moreover, once it is on, I can unplug the power supply and listen to the radio for several hours just using the batteries. Note that my battery pack is now ok and seems to be charged normaly.
So, I think, the problem is only related to the battery charge level detection. Am I clear enough?
Does anyone faced the same issue? The problem might come from a single & simple component (maybe a
damaged capacitor, a zener diode or whatever), but I really don't know yet.
Old 11th February 2012, 10:50 AM   #9
cjrmcw is offline cjrmcw  United Kingdom
cjrmcw's Avatar
Hi NicoLarve, guys. Did you solve the "radio won't turn on without the help of the power supply!" problem. I have one which is doing exactly the same.
I did take the back off a while ago and found that a quick short-cut across two adjacent legs of the three-pin voltage regulator would bring the set on with charged batteries and without the PSU. Now that can't be right, so I wonder if one part of the voltage regulator is blown? But is that really the component that detects the right voltage?
Old 26th May 2013, 08:06 AM   #10
Hi!
Slightly old thread but I've had the same problem regarding radio won't turn on without power supply connected. Anyone found a solution for this?
/Roger
Tivoli speaker Kees Full Range 21 24th February 2011 06:53 PM
Chip amp to use with Tivoli speaker kenneth Chip Amps 4 17th February 2009 10:07 AM
Tuning LED a la Tivoli tubenut Analogue Source 2 8th December 2006 06:33 AM
Tivoli Model1 PSU hum fix / upgrade? jives11 Solid State 1 24th May 2004 09:30 AM
lm1875+battery problem PauSim Chip Amps 38 6th February 2004 03:45 AM
Copyright 1999-2017 diyAudio
