I am about to order some parts. I generally like to order parts that are made by a good manufacturer, although I use the ECG device specs for design. I need some part numbers that are like ECG2410/ECG2411 transistors. They are surface mount, SOT 23 case package, very small.
Vbe=150V Ic=400mA Pd= 200mW Hfe=150-200 Ft=300MHz Using them for current sources and current mirrors. If anyone has any part number suggestions for these componants, I would be greatfull. Thanx, Chris |
#2 |
Hi Chris,
I haven't looked, but why not use on-semi's selector guide? That's where I start looking for specs. when I'm in the design phase. Then you can cross to ECG / NTE . Just kidding. -Chris |
#3 |
Thanx, I will investigate you suggestion.
#4 |
These specs remind me to the good old 2N5401 and 2N5551 through-hole TO-92 transistors
Maybe you can find SMD versions of them |
| suggestions for transistor upgrade | miner79 | Parts | 3 | 16th August 2008 09:14 AM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| who knows this transistor? | d.O.LF | Solid State | 16 | 5th March 2007 08:46 AM |
| Transistor name | ObliVion | Everything Else | 1 | 21st October 2004 09:34 PM |
| Some quick transistor suggestions | alvaius | Solid State | 2 | 26th April 2002 11:04 AM |
| Page generated in 0.08143 seconds (70.37% PHP - 29.63% MySQL) with 10 queries |
