Reinventing the N-channel wheel?
Old 2nd November 2007, 07:27 PM   #61
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Any news on the project?
Old 30th November 2007, 06:53 PM   #62
marus is offline marus  Romania
Send a message via Yahoo to marus
Where are the pictures and schematics from this thread ? I don't see any ... From the beginig there are no schematiscs ...
Old 30th November 2007, 06:58 PM   #63
Tim__x is offline Tim__x  Canada
This thread is three years old, sadly it seems Eva has removed the pictures from her website.
Old 1st December 2007, 09:24 AM   #64
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
The images were not deleted, they were just moved to a case sensitive host and the original files happen to have the name in upper case while I used lower case in my posts. I think that I have fixed all the file names. The same problem happens with the images that I posted in other old threads.
The breadboards of this project are still resting in one corner covered with a plastic bag to avoid dust. I may continue some day, but now I'm deeply involved into class D development, as lumanuaw cleverly predicted almost two years ago. Some of my current class D work may be seen in the class D forum.
I use to feel like the small child in The Emperor's New Clothes tale
Old 1st December 2007, 07:04 PM   #65
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default I will follow your class D project.
I am interested to learn and to construct to my own use.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 5th April 2010, 09:38 AM   #66
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Default Sorry it is long ago, just to say thanks.
Actually I'm searching for cheap amp project, but I've found this kind of input stage. It is new for me and I think I've got the point, a strong differential.
May I ask you your experience with this stage? Is there ever a problem caused by this input? Because it is very rare, might there some errr.
I have planning to use this kind in my follower amp, it need stronger differential than currently used.
Sorry this thread was long ago, but thanks for this post.
I'm stopped designing class-D but I'll just looking at yours.
Sadly this project ended here. I've enough experiencing myself with DMOS in power conversion and Amps, Floating Driver is the best way DMOS Amps for me.
Old 5th April 2010, 01:14 PM   #67
ontoaba's Avatar
I'm realize some disadvantage in this differential, now.
Yes it has stronger gain, but it is not much better. Some transistor already with almost constant Vbe at certain current region.
Both input will interfere, and some more problem, like stability and performance in stressed condition.
Old 5th April 2010, 02:44 PM   #68
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
MOSFET's are limited by the package they are in for power dissipation.
Some specs seem a bit optimistic to me especially the IRFP260.
I usually use IRFP240's (1-50) in my designs as they are cheap and not optimistic with power rating.
I believe an amplifier needs cross conduction to get rid of crossover distortion.
Simulations can be used as general pointers but are rarely exact.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 5th April 2010, 03:32 PM   #69
Elvee is offline Elvee  Belgium
Elvee's Avatar
I think you dismiss this circuit a bit too quickly: it is very smart and clever indeed (what else would you expect from Eva?..).
It looks like a variation on the Xquad, but without some of its problems.
The accuracy and linearity, compared to a plain differential, are outstanding: practically one order of magnitude improvement.
Old 5th April 2010, 11:17 PM   #70
kenpeter is offline kenpeter  United States
Originally Posted by Eva View Post
That's pseudo-class-A stuff. It keeps the ouput devices always biased to an adjustable current level (R79 and R80) and there is another "AC cross-conduction" adjustment (R78). That reduces gate-charging spikes (the ones in Ic(Q17) and Ic(Q18)) to an absolute minimum. These waveforms also show the extreme non-linearity that MOSFET devices show in class-B at high frequencies, even in the harmless PSpice models with linear capacitances.
In PSpice it looks beautiful, as always...
I have a much simpler diode crossed output stage that does exactly this.
But an entirely different method, and drastically lower parts count. Search
my recent posts... Granted, I havn't yet tried grafting your input stage
with my output. That combo might be a winner... My methods are kinda
screwy: I do let Schottky devices sometimes turn off, but only Schottky.
You demand the right set of always-on AB curves for sure. I agree with
need for active pull up and down when it comes to driving MOSFET gate
capacitance with any symmetry, you got that right too. Just throwing a
few too many parts at an analog computing and driving problem that can
be solved an easier way.
Reinventing the N-channel wheel?Hide this!Advertise here!
Geared wheel for Phillips CD850-MK2 Maurice Digital Source 112 2nd November 2011 05:50 PM
Ferris Wheel Project mattthegamer463 Everything Else 14 31st May 2009 08:37 PM
New kind of feedback or just re-inventing the wheel? Circlotron Solid State 51 9th March 2003 08:02 AM
Copyright ©1999-2017 diyAudio
