I want to make a good quality amplifier that will produce about 100-150W/8 Ohm and will do 4 Ohm load. I can solder fine and have made various other electronics things. I know some basics about amps but not the theory on how they work so I am really loooking for a tried and true design without much trial and error/tweaking. I can make my own single sided PCBs from an image but I am not that confident in doing the layout. I have already made a Gainclone. I was looking at this one from Jaycar because it was cheap: ![]() Refer SC March/May 2000. This class AB amplfier delivers a clean, low distortion output of 100 Watts RMS into 8 ohms. The amplifier design is rather unique in that the early stages are powered by a regulated power supply to enhance the overall performance. The output stage is unregulated to ensure good transient response. Specifications: * Frequency response: -0.3dB down at 20 Hz; -0.5dB at 20 kHz. * Input sensitivity: 1.8V RMS (full power into 8 ohms). * Harmonic distortion: <.006% from 20Hz to 20kHz, (typical <.002%). * Signal-to-noise ratio: 117dB unweighhted (20Hz to 20kHz); 123dB A-weighted. * Damping factor: >170 at 100Hz & 1kHz; >60 at 10kHz. * Stability: Unconditional Short form amplifier kit includes PCB plus all on-board components. Requires Chassis, HH-8630 heatsink and KC-5289 power supply kit. But I heard some bad comments on them in these forums. I was thinking a maybe Pass Labs one? |
#2 |
Hi Max,
There are so many good amps to build, but I believe you can't go wrong with an AKSA. I'm very happy with mine. At a guess, I think an AKSA 55 would be more than adequate for your nice DIY speakers. How does your gainclone drive them? From information on these forums, the Pass Labs ones are very good also, but are generally class A amps unlike the SC amp which is class AB.
Greg Erskine |
#3 | |
The AKSA 100 looks good but from the FAQ it looks like you have to buy the whole thing as a kit which costs $AUD690 which is alot, probably too much to pay up front.I haven't tried my GC with my speakers yet as I am still sourcing parts for its case. But the amps I am wanting to make from this thread will be used to power a pair of 12" subs, hence the more power required |
#4 | ||
![]() Sorry for the misleading information in my previous post.
Greg Erskine |
#5 | |
Anyone used these? http://www.aussieamplifiers.com/ampkits.htm They have good specs and are a cheap place to start |
#6 |
Well you might have a look at www.hypex.nl and look for the UcD180 module. At 60 euros each they are a steal (well compared to $690 at least). Unfortunately they won't give you much construction pleasure - they're finished modules and require only a power supply to go.
#7 | |
And they are quite cheap too. Are class D amps still confined to sub woofers? |
#8 | |
The specs of the hypex modules show that they are equally at home at 20kHz as at 20Hz. For user testimonies (sound quality etc), have a look at the thread titled 'UCD180 questions'. |
#9 |
you could do worse than use a ESP p3a, you'll need to furnish it with a TNT style psu for the best bass response (more critical than the amp itself IMHO). In my experience, the Tranny size, C size and use of one bridge per rail are important, the other details less so, especially if it's only for sub F's.
ESP p3 gives details of how to use more o/p devices, which may be useful given the load you are contemplating. I am using this setup with 30-0-30 Tr's and bog-standard components (bar MJ15003/4 o/p devices in the p3a) with 88 dB/W speakers and power is really not an issue, even in large rooms.
We will pay the price, but we will not count the cost... |
#10 | |
| Please recommend a tube DAC to build. | JayH3 | Digital Source | 1 | 26th May 2008 01:50 AM |
| Pls recommend a power amp to build? | pengboon | Tubes / Valves | 39 | 17th August 2006 04:53 AM |
| Recommend a floorstanding 2-way to build? | happyb | Multi-Way | 6 | 12th March 2006 03:39 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Page generated in 0.12078 seconds (83.44% PHP - 16.56% MySQL) with 10 queries |
