#131 |
Another new wrinkle, along with a further set of tweaks - in the circuit below, the sonics (as well as THD) can be tuned by adjusting a single resistor, R18. If it's low, the H2 component is significant, but the THD is also higher - similar to the classic JLH1969. By increasing R18, it's possible to progressively lower the THD, but at the cost of decreasing the H2/H3 ratio.
In principle, it's possible to have a selector switch (or maybe a CD4066 quad-bilateral switch) to select the desired sonics from the front panel - say Classic JLH, Normal or Low-Distortion; or maybe even a log-potentiometer. |
#132 |
Here's the simulated 16W THD20 FFT at ~ -60 dB THD (R18 ~= 4.7k):
#133 |
Here's the simulated 16W THD20 FFT at ~ -80 dB THD (R18 ~= 47k):
#134 |
Here's the simulated 16W THD20 FFT at ~ -100 dB THD (R18 ~= 470k):
#135 |
An idea for input bootstrapping on the original 4 transistor JLH topology follows - this is only a concept for simulation, although it could be built to deliver >2.5W into 4 ohms with a single +12v rail.
The main idea here is to increase the input impedance sufficiently to allow the use of a small input coupling capacitor, which could be high quality, e.g. styroflex or silver mica. |
#136 |
And here's the THD20 FFT at 2.5W into 4 ohms.
| Graham Maynard | Stocker | Everything Else | 0 | 28th March 2007 03:47 PM |
| deleted Graham Maynard thread | SY | Solid State | 0 | 16th October 2005 11:52 AM |
| First cycle distortion - Graham, what is that? | peranders | Solid State | 115 | 29th April 2004 03:24 PM |
