Old 1st September 2004, 03:27 PM   #1
Default opinion on MOSFET amp?
Which is better?
- JFET voltage gain stage on input with mosfet follower on output
- buffer stage on input with mosfet gain stage on output?
this is for a SE Class A amp.
mosfet probably loaded with either a choke or an output transformer.
Thanks!
Old 1st September 2004, 05:22 PM   #2
ashok's Avatar
Default Commercial or personal ?
I wouldn't comment if this is for commercial use.
For personal use I'd say you should use buffer with MOSFET gain stage. It would be interesting with a transformer coupled output.
Choke load would still need a capacitor. That's two unwanted things. With a transformer ( better understood ) and direct speaker connection to the secondary , you'd be in a more commonly used area. I would think it is a better configuration to try out. Capacitors are so finiky you may end up using one costing a fortune to sound good.
I've been trying to find something ( cheaper ) as good as a coupling capacitor from Jensen PIO ( paper in oil ) and I haven't found one yet.
So out with caps if you can manage it !
Cheers.
AM
looking for opinion xxxwhezzy Car Audio 9 8th May 2008 04:53 PM
mosfet opinion? tadiam Solid State 13 30th March 2007 05:33 PM
35W MOSFET Power Amp - Your Opinion binary Solid State 20 17th November 2006 12:25 PM
My N_channel Mosfet Amplifier-opinion zox2003 Solid State 9 9th April 2005 11:46 PM
Elektor- MOSFET 'valvesound' amp opinion mikee12345 Solid State 0 7th August 2004 06:53 AM
Page generated in 0.06245 seconds (68.58% PHP - 31.42% MySQL) with 10 queries
