Old 31st August 2004, 11:54 PM   #1
Risto80 is offline Risto80  Macedonia
Banned
Send a message via AIM to Risto80 Send a message via MSN to Risto80 Send a message via Yahoo to Risto80
Question Problems with UPC1237
Hello
I like to build a protection for speacker and I have schematic for upc1237 but i dont undrstand about relay.My amp will run on +/-40V Sow what kind of relay should i get and how high should be the resistance in relay to put suitable resistor on pin 6 of upc1237
Old 25th December 2004, 07:51 PM   #2
Relay contact current depends of amp power you've got!
I think for 150W amp like i got and also planning protection with that IC's is that 10A 300V contact is ok solution.
Marin
Old 25th December 2004, 11:33 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Post Data sheet
Hi Risto80,
The resistor limits the current into pin 6, max. 80mA. Set this to drop the proper voltage across the relay coil depending on supply voltage. You can boost this rating with a transistor or two. Do you want the PDF? The file is too big to attach it here. PM to bhome_at_sympatico_dot_ca .
-Chris
Old 26th December 2004, 11:29 PM   #4
Banned
Default Hello
Put the schematic in .jpg format or send on my e-mail risto44091@hotmail.com
Old 27th December 2004, 02:38 AM   #5
anatech's Avatar
Hi Risto80,
You have mail.
-Chris
uPC1237/NTE7100 d3imlay Solid State 37 9th May 2012 02:49 AM
Question on uPC1237 Buzzy Solid State 18 3rd August 2008 01:22 AM
Upc1237 Ic d3imlay Solid State 3 7th February 2008 12:14 PM
upc1237 circuit diagram.. clovi_kate Solid State 1 4th May 2007 10:16 AM
UPC1237 IC Amp Protector matt09 Chip Amps 5 2nd November 2006 06:59 PM
Page generated in 0.08396 seconds (73.95% PHP - 26.05% MySQL) with 10 queries
