I've seen the volume pot added before the preamp, sometimes after the preamp, sometimes between the gain stages in the preamp.
Is there a preferred position that gives a better performance or is it dependant on the preamp design? Does the same also apply to added tone controls or equalisation? |
#2 |
It's usually a trade-off between noise and overload headroom.
If you put the gain control pot right at the input, then obviously you get the best immunity to clipping, but all the stages after the pot are operating at max gain and each will be adding noise. Conversely if you put the pot late in the signal chain, then as you turn down the volume, you are also reducing the noise. The problem is that a high-level input could cause stages before the gain-control to clip. That's why the control is often about half-way down the chain! Wherever you put it, be careful that the stages before the pot aren't going to clip. (perhaps by giving each input its own input-level setting pot.) |
#3 |
Thanks for your reply........ very informative.
Cheers |
#4 |
There was once a Marantz amp with volume control in two different stages (using a quadruple ganged pot) in order to get the best compromise between headroom and noise performance.
Regards Charles |
#5 |
I have enough trouble with a dual pot.
#6 |
But the four gang pot may be a linear taper, they track better.
| c'mon guys, lets put our heads together to control a STA310 ac3 decoder | emuman100 | Digital Line Level | 224 | 30th July 2011 07:50 AM |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.08817 seconds (75.62% PHP - 24.38% MySQL) with 10 queries |
