Old 4th September 2004, 05:05 AM   #11
andy_c is offline andy_c  United States
Banned
Oh, just one more thing. If your load current varies a lot, you should consider using a series regulator like the LM337 instead. The TL431 is great for replacing low-power zener diodes, but your load current might spike to a high value and cause the TL431 to turn off. You haven't said what your application is, so it's hard to say.
Old 4th September 2004, 06:10 AM   #12
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Just regulating the voltage feeding a low power opamp. Never toyed with the TL431, and I thought now would be a good time to try it out.
I don't think that the current draw will spike enough to affect the TL431 (should be rather low) so I hope I'll be fine. Otherwise I can always revert to a series reg, just wanted to try a shunt this time around though .
Oh, and again, thanks alot for all your help, I'm almost done my board and I'll see how it works soon enough.
Old 4th September 2004, 08:43 AM   #13
Raj1 is offline Raj1  United Kingdom
I think there was a series of tests on TNT audio with series and shunt regs. In these types of low current apps the shung regs outperformed the series regs, they genrated less noise. So for low current opamps these regs are probably a good bet.
Raja
Old 4th September 2004, 12:56 PM   #14
jackinnj's Avatar
You can always use the TL431 to drive the base of a PNP or NPN power transistor. Then you don't have to worry (as much)about frying the critter.
Ambient isn't always "ambient" -- as in the case where you put the device in a box with other devices which are heating.
I need a negative supply rail--but how? wally.gribbles Tubes / Valves 5 18th February 2008 08:36 PM
Full negative rail voltag on my output?? aletheian Chip Amps 1 26th October 2005 05:38 AM
TL431: Can it regulate 300V DC? Danko Power Supplies 11 26th September 2005 11:45 AM
Need Help on Calculations for Negative TL431 with Pass Transistors!! Tubist Power Supplies 10 27th April 2005 11:58 PM
GC problem: voltage dropout on negative rail scone Chip Amps 6 14th January 2005 08:15 AM
Page generated in 0.08157 seconds (72.10% PHP - 27.90% MySQL) with 11 queries
