I've recently picked one of these up as an ebay bargain and am very pleased with it as far as detail goes but it does sound a little thin and the bass is lacking even with a good signal.
I was wondering if upgrading the opamp from the JRC 45580 to an OPA2604 or AD843 and generally uprating the capacitors in the power supply/amplifier sections to panasonic FC 50% or so larger than the existing itemswould go some way to fix these shortcomings. Sony have used a combination of standard and nichicon VR or VR1. Should I just concentrate on replacing the items thought more important by the designers? If anyone could take a look at the schematic and suggest some first steps to improving things I'd be greatful. Sony ST-SB920 Manual |
#2 |
Hi, i know this is an old topic but i wonder if you made any mods to the ST-SB820 tuner?
Mine sounds a little bit thin also. I would suggest to replace the coupling caps in the audio stage by a somewhat greater value, and replace the opamp by the OPA2604. And replace the muting transistors by a solid-state relais.
| Another broken Sony receiver... won't turn on | rkc7 | Solid State | 40 | 10th February 2012 10:05 AM |
| sony 6ch receiver help | thetube0a3 | Solid State | 1 | 30th March 2009 06:41 PM |
| Sony Receiver GX60ES for $100, is it worth it? | gychang | Solid State | 0 | 31st January 2007 02:15 AM |
| Realistic and Sony Receiver Questions | alloyskull101 | Solid State | 0 | 9th January 2005 08:10 PM |
| A broken Sony receiver | nickia | Solid State | 7 | 23rd March 2004 02:53 AM |
| Page generated in 0.08804 seconds (70.41% PHP - 29.59% MySQL) with 11 queries |
