12vac to 12vdc what all do i need
Old 25th August 2004, 04:14 AM   #1
Big_Tires is offline Big_Tires  Canada
Big_Tires's Avatar
Default 12vac to 12vdc what all do i need
this subject has been troubleing me for weeks i had just bought a new transformer that converts 115 volts ac to 12 volts ac , so my question really is do i just need a rectifier or do i also need other things
if you could help that would be awesome thanks
you can aso e mail me at Big_Tires@hotmail.com
Old 25th August 2004, 08:12 AM   #2
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
A bridge rectifier and an output smoothing capacitor may be all you need. How much current do you need to supply?
Old 25th August 2004, 09:37 AM   #3
hjelm is offline hjelm  Sweden
hjelm's Avatar
If you have 12VAC RMS from the transformer you will have some 12*1.41 -1.4v after the rectifier and caps. ~15.5 volts depending on how much current you consume.
If you want to have 12V from this i recommend to use a three terminal voltage regulator (like a 7812) that takes the 15.5 down to 12 V, the regulator might need a minimum current draw so check the datasheet of the regulator and the thing you want to supply power to. You need another cap after the regulator as well.
78XX datasheet Contains a typical application, see top of page 8.
If you have 12V peak then a bridge rectifier and some caps will give you less than 12 volts due to the voltage drop over the diodes.
It all depends on what you want to do with it. There are more advanced solutions as well.
Edit: Just noted that this thread is placed in a strange location shouldn't it be moved to some other location???
Hjelm
Old 25th August 2004, 06:48 PM   #4
Big_Tires's Avatar
Thanks for the help im going to power 2 computer fans to cool my home amplifier, but i tested my transformer and it puts out 14.7 volts.
Old 2nd September 2004, 12:32 AM   #5
cunningham is offline cunningham  United States
Computer fans will not last long with overvoltage due to the way it is constructed. The coils will burn up. A 12VAC transformer will output 18V peak, this is what you will see on the filter caps with no load. Slightly less depending on current drain. You should make a regulator for 12V. If you want to keep it really simple, use a 7812 Voltage regulator IC. Or you could use a 13V zener diode as a reference and amplify this reference with a darlington BJT, emitter follower, Ve will be at 12V. Either will work just fine.
Old 2nd September 2004, 12:33 AM   #6
oooopss my bad....7812 was already mentioned. BTW LM317 adjustable regulator will work also.
12vac to 12vdc what all do i needHide this!Advertise here!
My LM3886 Stereo Amp. w 12-0-12VAC Transformer Andreq Chip Amps 27 1st May 2011 06:32 PM
Anyone tried this 12vdc 1A supply? dublin78 Power Supplies 1 11th June 2009 05:27 PM
12vDC to 12vAC Cxrazy Parts 10 21st January 2008 02:11 PM
How to get +15v and -15v from 12vdc mbcouple Everything Else 15 25th June 2005 06:25 PM
URGENT 9vac to 12vac Guss Everything Else 1 26th September 2003 02:54 PM
Copyright ©1999-2017 diyAudio
