I am rebuilding a Marantz 2330B receiver that has the original toshiba output transistors , I am collecting parts presently ;considering 1 channel has shorted outputs. I could source the original type , but am concerned about getting fakes. Is the MJ 15024 or MJ15016 a decent sub? Having trouble finding details on the originals.
Thanks |
#2 |
If you can get your hand on some MJ 21195/96's you won't go wrong. I've used them in numerous amps and have nothing but praises for these new beauties.. They are just fantasic audio transistors.
Ralph Electronics Tech. |
#3 |
Hello gents,
I only can confirm that the MJ 21195/21196 are perfect substitutes for your originals. I have used MJ21193/21194 which have slightly lower SOA in several Sony and Technics Amps successfully. Due to my information the originals do have a wider bandwith but it seems to be more forgiving to use slower substitutes than faster ones. |
#4 |
If you cant get the MJ21195/96 get some MJ15024/25 which are easily available everywhere and are used lots in amp output stages.. They may have a low bandwith but are more then acceptable...
#5 |
Thanks for the input , will proceed with your recommendations.
| 2sk3662 substitutes? | shagone | Car Audio | 8 | 29th November 2011 04:33 AM |
| Substitutes | cobology | Parts | 0 | 21st February 2009 08:59 PM |
| Op Amp substitutes | mosfetti | Solid State | 8 | 7th December 2007 01:13 AM |
| 7868 substitutes | AmpKiller66 | Tubes / Valves | 7 | 21st November 2007 03:19 PM |
| substitutes for 2SC3519 | Antonix | Solid State | 5 | 14th October 2005 10:57 PM |
| Page generated in 0.07534 seconds (73.44% PHP - 26.56% MySQL) with 10 queries |
