Old 22nd August 2004, 09:58 AM   #1
markzb is offline markzb  Malaysia
Default How do I make a terminated test lead?
Hi everyone
Hope you can help this newbie!
I bought myself a used function generator which is hard to get hold of this side of the world. Its a Leader LFG-1300S and Im so glad to have this toy.
Anyhow, I got a copy of the manual and it says that when you want to do amplifier testing, you need to terminate the line with a 50 Ohm terminator on the amplifier input.
On the generator itself there is a female 50 Ohm BNC connector.
I would like to make a test lead that has a BNC male on one end and a pair of RCA's on the other.
My question is kind folks, how do I build a test lead that incorporates this termination into it.
What bits should I buy?
Many many thanks!
mark
Old 22nd August 2004, 05:19 PM   #2
leadbelly's Avatar
Could you perhaps quote parts of the manual in more detail? My 1st inclination would be that the manual is instructing you to terminate the unused input of the function generator when you are using its output for testing amplifiers.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 22nd August 2004, 05:22 PM   #3
jackinnj's Avatar
you can buy 50 ohm terminators -- Tektronix or Hewlett Packard -- on EBay --
Old 23rd August 2004, 03:02 AM   #4
Hi Jackinnj
Thanks for your reply. I am able to buy a terminator here at farnell. My problem I guess is that I am not sure how to use it!!!!!
Would it be ok and correct if I buy a coax cable of say 3 foot length with BNC's on both ends....one end into function gen, and one end into the terminator. Then from this terminator, I hook up a BNC to RCA adaptor to connect to audio gear. Is this correct?
Many thanks guys
mark
Old 23rd August 2004, 03:48 AM   #5
leadbelly's Avatar
I found this link:
http://www.tele.pitt.edu/Main/Resour.../laboscope.pdf
As you can see, it makes no mention of a 50 ohm terminator when wiring up your FG, just a straight cable with 2 alligator clips and a BNC on the other end.
Have you perhaps read too much into some phrasing in the manual? 50 ohms is the characteristic impedance of the BNC connector and cabling, and termination can simply mean connecting a cable.
Old 23rd August 2004, 11:25 AM   #6
jackinnj's Avatar
for audio it probably isn't necessary when you are just starting out -- for radio frequency (and up) it becomes important -- the generator wants to see a uniform load across the spectrum you are measuring. if the load is mismatched a portion of the signal will be reflected back to the source, when it is fed back it will add and subtract the generator output. the reflection is the bane of our existence for those who design their own antennas and feed systems.
50 ohms is standard for RF work.
on cables -- RG58 has a characteristic impedance of 50 ohms while RG59 is 75 ohms. even the connectors have an effect upon the impedance -- RCA plugs and jacks are pretty awful for RF, but adequate for audio.
as you move up the money chain the impedance match gets better and better, but it isn't a critical issue at audio (I am sure that there are some out there who use gold-plated SMA connectors for audio.)
Old 23rd August 2004, 03:11 PM   #7
Hi Guys
Many thanks for your replies. Muchly appreciated! I wont worry too much about it then!
For now......
Cheers
mark
Old 23rd August 2004, 07:57 PM   #8
moamps is offline moamps  Croatia
LFG1300 has PI 50ohms attenuators 10, 20 and 40dB at output, witch means that 50ohm terminator (or overall load) is needed to get correct (exact) attenuation ratio. I don't use this terminator at output because allways have scope and voltmetar connected and know what I have at output.
If termination is needed, simplest way is connecting BNC T-adapter on output and 50ohm terminator (two 100ohm metalfilm resistor parallel conected in one 50ohm BNC connector) on one output and BNC-2 alligator clips RG58 cable on second output.
Milan
Old 15th October 2008, 11:22 PM   #9
timetec is offline timetec  United Kingdom
Default Re Function Generator Manual
@ markbz - would it be possible for you to tell me where you obtained your LFG-1300S Function generator manual please ?
I've been looking for a copy for months, but have had no luck in finding one.
Many thanks in advance
How to Make Test Signals in WAV format d1camero Digital Source 15 23rd August 2010 04:44 PM
JP2.0 Part IV A.K.A. first test photos don't make fun of my cardboard DIY_newbie Multi-Way 24 1st September 2005 05:05 AM
Make Your Own Test Cd!!!!!! OMNIFEX Multi-Way 6 7th April 2003 01:24 PM
Terminated Interconnect Cables carlmart Solid State 17 4th January 2003 09:23 AM
Page generated in 0.11163 seconds (75.07% PHP - 24.93% MySQL) with 10 queries
