which VA and VAC ratings do you advice me to do à 300W @ 8 ohm audio amp ? The first i've made (thanks to this forum) need 2 x 35V to give about 90w @ 4 ohm. What's the formula to get these parameters ???
I think almost all the loss are in the output state (MOS) ?? Thanks |
#2 |
Too little info. Type of amp (Class A Single-ended, Class A PP, Class AB, Class D etc...). Preferably type/schematic...
UrSv Those who say it can't be done should not stop those who are doing it. |
#3 |
sorry ... it's class AB output stage, IRFP240 (MOS). I have not the schema yiet ...
David |
#4 |
(and of course IRFP9240 also )....
#5 |
for 300W amp u need about 500VA transformer
#6 | |
well, I just thought that class A would be out of the choice. 300W RMS with 20% efficiency? |
#7 |
60-0-60AC will give ±85V no load, 500VA is good for me.
#8 | |
#9 |
Check out Rod's subwoofer amp.
http://sound.westhost.com/project68.htm
MikeW |
| Toroidal VA rating | Nate805 | Chip Amps | 11 | 15th November 2008 08:29 AM |
| Question: Toroidal transformer rating | siuguyguy | Power Supplies | 4 | 26th September 2006 02:08 AM |
| Transformer rating | xplod1236 | Chip Amps | 3 | 7th July 2004 12:58 AM |
| Transformer VA Rating vs. Current Rating | JhonDoe | Chip Amps | 45 | 5th June 2004 01:11 AM |
| Toroidal Transformer Insulation Rating | 316a | Parts | 13 | 28th July 2003 09:51 PM |
| Page generated in 0.09872 seconds (77.37% PHP - 22.63% MySQL) with 10 queries |
