Tonight I roughed out a power supply for the Holton AV800 amp I am building and when I checked the rails of the supply the negative rail was about 96v and the positive rail was about 92v.
What the heck? Both windings have identical output. I am using some large capacitors and I only used two per rail instead of the planned 5 per rail, could the capacitor tolerance account for the discrepency? Thanks for your comments.
Anything worth trying is worth failing at once or twice. |
#2 |
What do you mean if you say: "both windings have identical output"?
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
I am assuming he means that when read with a multimeter/scope not in the circuit the secondary outputs (positive and negative) with respect to ground are opposite but equal in magnitude and when he has the rectifying and filter caps hooked up, the rails are uneven. I don't know the answer to why, just thought it would help to clear things up though.
Its possible one rail contains a bad cap that has a modest (READ more than miniscule that all caps have) resistance. Try swapping caps between rails and see if the problem reverses itself. |
#4 |
Well, you assume a lot. I'd like to hear it from the horse's mouth before starting on some speculative course. After all, if you don't know the indications, how can you solve the problem if you don't know what it is?
Jan Didden
#5 |
Frazzled,
I would try to put a light load on the supply. Maybe a some 100mA on each polarity to GND. Then measure again. With that voltage bleeder resistors are called upon for discharge in case of service after a failure. Try put in 14.7 kOhm / 1 W on each rail. Maybe that is already enough to EQ your voltage. / Mattias |
#6 |
dswiston You are correct. When I measure the AC voltage from each winding without rectification or filtering (2 secondary windings for +/- supply) I get 68.2V from each.
I have 5K 8watt bleed resistors on each rail. The resistors were matched and are exactly 5K (that took some time to do let me tell ya)I am going to try switching the caps around to see if that has any effect, it was just too late last night to start fooling around and i was tired and didn't want to make any stupid mistakes. Thanks for the help.
#7 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#8 |
It seems the positive rail has some strange defect. 68.2volt from
the windings should result in some 96.4v. Is something heating up ? What is the voltagerating for your caps ? Maybe the rectifier is defect, or does not withstand 200volts ? I do not believe that a cap is defect, it is very likely it would have blown already. (With these voltages: detonated !) Mike |
#9 | |
Sorry forgot to specify that the supply is just sitting on the bench not hooked up to the amp.
As I said I am going to switch the capacitors with 4 different ones this morning to see if there is any effect. Quote:
I'll update shortly. Thanks for the suggestions!
#10 |
This is indeed fishy. Unloaded, the caps should charge to the same (peak) value. If there was a difference loaded, I could imagine that there was an error in the bridges, and that the lower side would only have half-bridge rectification.
A difference in cap leakage could also cause it, there will be a relative large difference between zero load and a little load. Let's see what your cap switching gives. Can you post the schematic, how you have interconnected the secondaries, bridge, caps? Jan Didden
| Question about using 2 ports of unequal length. Why? | Brisso57 | Multi-Way | 19 | 22nd August 2008 09:09 PM |
| Unequal port length = OK ?? | MadMutt | Subwoofers | 9 | 4th January 2007 01:28 AM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Page generated in 0.10921 seconds (79.03% PHP - 20.97% MySQL) with 10 queries |
