Hello everybody.
I'm a new diy from thailand.I decide to make a poweramp by my self. I don't know about how to measure distrotion ,THD ,TIM I have Ocscilloscope and function generator. and DVM. Help me please.. Thank you .. everybody
PapaNohn |
#2 |
You can't measure distortion with those tools. You need a distortion analyzer.
dave |
#3 |
The one and only
You can make a distortion analyzer, though.
#4 |
it is difficult to measure distortion with a analog 'scope but high end digital scopes do have fft/spectrum analysis options
nulling/differencing and notch filtering can allow you to look at "distortion residuals" with a analog scope but its not easy or flexible today's cheap option for audio measurements is the PC sound card and spectrum analysis software - freeware such as RightMark RMA gets you started with almost any PC (a handfull of attenuators, decoupling caps and possibly analog filters/buffers to interface high power amp V to the soundcard input/output are recommended ) M-Audio Transist is recomended as a cheap USB external sound card with a 24/96 codec that has great performance for ~US$ 80 check out tools and resources threads at headwize and head-fi |
#5 |
Thank you for all.
PapaNohn |
#6 | |
You also need a low distortion oscillator -- if this is your first gambit consider an oscillator for only one frequency -- 1kHz. Here's a simple idea which will work -- you use a basic crystal controlled oscillator -- 32.678 kHz crystal and divide down by 32 to get a ~ 1 kHz square wave (or a 1 MHz crystal and divide by 1000). Follow this by a couple of op-amp low pass filters and you will get a reasonably low-distortion sine-wave oscillator. Once again, TI has good free-ware for designing low pass filters. Search for "Filter-Pro" on their website. If you have access to the Linear Technology or Maxim higher order switched capacitor filters these can be used -- they aren't that expensive -- an 8th order low pass filter from Linear is about $2.00. Jack |
| So how do you measure power amplifier PSRR then? | GK | Solid State | 22 | 21st December 2008 02:09 AM |
| Test/Measure power amps | samsagaz | Parts | 2 | 27th May 2008 04:22 AM |
| How to measure amp power output | hernanstafe | Parts | 2 | 16th February 2007 01:27 AM |
| Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? | percy | Multi-Way | 0 | 12th March 2006 09:18 PM |
| Can you measure Sd? | ultrachrome | Multi-Way | 12 | 28th March 2003 04:37 PM |
| Page generated in 0.09084 seconds (73.72% PHP - 26.28% MySQL) with 10 queries |
