Old 18th August 2004, 05:21 PM   #1
Sunsun22's Avatar
Default Why some components have to hang above PCB?
I am curious to know why some components have to hang above PCB like this one as shown other than reasons of heat: -
Old 18th August 2004, 05:28 PM   #2
tbr is offline tbr  Switzerland
Interference with tracks on the pcb below, isolation issues at hv units, positioning space of the robot somewhat limited (but seldom),...
Thomas
Old 18th August 2004, 06:07 PM   #3
Electrons are yellow and more is better!
peranders's Avatar
I would claim that in 99% of the cases it's about hot parts. Better cooling simply. I can also be that you don't want some other sensitive parts to get hot.
It can also has something to do in the soldering process. Those parts maybe _not_ be able to handle the heat from the wave soldering.
/Per-Anders (my first name) or P-A as my friends call me
Old 19th August 2004, 01:56 AM   #4
Sunsun22's Avatar
Thank you for the input. Would like to know what are the criteria to determine which component should hang above PCB to prevent interference from tracks in PCB?
Sunny
Old 19th August 2004, 02:11 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
Default Hot Parts
Hi Sunsun22,
peranders is right. Hot parts are stood off the pcb so the pcb doesn't get damaged. If the part is this hot, you don't want the pcb to be used as a heatsink. High voltage parts are stood off to cut down leakage currents, you may find the pcb cut at right angles below the part depending on voltage or leakage sensitivity. The other reason to stand a part off is one that may burn in a fault, again so the pcb is not damaged.
The ceramic standoffs in your picture normally would indicate a hot part.
-Chris
NCD components rootbeer Class D 4 15th March 2009 05:09 PM
SAE Components Marc S Swap Meet 7 28th May 2008 03:14 PM
For sale or trade: Lots of stuff. Help me get the hang of DIY audio! Spasticteapot Swap Meet 1 1st December 2006 05:44 AM
What are these components? Mrpong Parts 4 15th January 2006 10:33 AM
amp and components for a 911? jbrinkely Car Audio 2 23rd September 2004 01:18 PM
Page generated in 0.08951 seconds (69.65% PHP - 30.35% MySQL) with 10 queries
