why a cap and resistor at output of leach?
Old 12th August 2004, 12:41 PM   #1
Wagener is offline Wagener  South Africa
Default why a cap and resistor at output of leach?
I am still battling with my leach amplifier. I am now only working on the one channel. The one which gives out dc from time to time.
First off. In the leach amp plans there is a 10ohm resistor and a 100nF cap connected in series which is to be connected at the output.
I do not have these two components at my output. What is the purpose of them?
I noticed this: When my amplifier idles (4-ohm load connected, input connected but without any signal, ie silence) the output transistors get extremely hot. This also causes the amplifier to give out DC. I found this out last night when I left for about 20minutes leaving my amplifier on with no music. When I got back my subs where making the typical dc noise and I noticed that the output transistors (and heatsink) were very hot. I could not touch it. I switched it off. connected Dc v meter and found that it once again gave out random dc.
I suspect that it is this overheating (while idling) that destroyed my other channel's output transistor.
Does it have anything to do with the resistor and cap that I don't have?
When I completed the amp I tested it on a oscilloscope I did not find any oscillation. I did however at that time still had the resistor and cap on the output. Removed it later because I believed it was just some filter.
Old 12th August 2004, 12:48 PM   #2
phase_accurate is offline phase_accurate
This thingie is called a Zobel and is actually there to improve stability, i.e. avoiding oscillation !!!!
Charles
Old 13th August 2004, 08:08 PM   #3
I missed the part in the leach amp plans which clearly states that R50 and C25 (which I removed from the output) prevents parasitic oscillations which causes the output transistors to become very hot.
That was the problem with my amplifier all the time.
I feel like an idiot!!
Well I am relieved that I found the problem
Thanks for all the help and suggestions from you guys!
why a cap and resistor at output of leach?Hide this!Advertise here!
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 03:55 PM
Resistor/Inductor at Leach Output BrianDonegan Solid State 10 22nd January 2005 07:22 AM
Leach output transistors pooge Solid State 5 14th January 2005 10:26 AM
dc on output of leach Wagener Solid State 9 7th August 2004 06:05 PM
Leach amp R37 - R40 resistor change!? supernet Solid State 4 23rd May 2002 01:07 AM
