Old 10th August 2004, 05:39 PM   #1
iain is offline iain  United Kingdom
Default Tvc preamp
I have just built a Tx102 based pre amp. I am unsure whether I have wired it up correctly and could do with some help I have wired the input to the wire marked "++" and the earth to "-"
It is switching in the gain that is confusing me. I have joined "--" and "+" together and wired the switch so that the input either goes as above or to the summed "+" and "--" is this right?
Also I have no DC blocking cap, do I need one? If so what should I use? Will it degrade the sound?
Thanks for any help
Iain
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Page generated in 0.04954 seconds (74.43% PHP - 25.57% MySQL) with 10 queries
