Luxman L-100 Schematic needed
Old 7th August 2004, 02:14 PM   #1
Calebay is offline Calebay  Denmark
Default Luxman L-100 Schematic needed
Hello
my old luxman got some problems. so i like to try fix it
Do anyone have the Schematic for it?
Old 7th August 2004, 02:42 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Hi Calebay
No schematic here but what's the problem?
/Hugo
Old 7th August 2004, 02:45 PM   #3
anatech is offline anatech  Canada
anatech's Avatar
Hi Calebay,
I have the SM. Not electronic. I used to be warranty so may be able to help.
-Chris
Old 7th August 2004, 07:08 PM   #4
neototem is offline neototem  France
you can try to order the manual from
http://www2.cgi.se/audio/
or
https://www.schaltungsdienst.de
Old 9th August 2004, 10:12 AM   #5
The one channel dies, but not completly dead. and its not all the time, but most of the time.
i can use the amp as separeted pre amp and power amp the problem above happens in the power amp part.
when i use the preamp part only. there also something wrong it, it sounds like distortion in the high tones, very easy to hear. and when i change to another preamp its gone
Old 9th August 2004, 10:43 AM   #6
Netlist's Avatar
Hi Calebay
You will solve a great deal of the problems with carefully resoldering the boards.
/Hugo
Old 10th August 2004, 02:47 AM   #7
anatech's Avatar
Default Clean first
Hi Calebay,
It sounds like switch contacts, clean the controls and switches. Don't forget to clean the output relay contacts. Make sure there is no residue of any kind on the relay contacts (or replace the relay).
Use Caig products or De-ox-id (General Cement I think), do not use too much cleaner. BTW, the slip ring in a control is what causes noise, not the carbon track. The carbon track has a protective grease on it, try not to wash it out.
Use normal troubleshooting techniques to find the HF distortion in the preamp after you clean the unit up.
If you find any bad solder joints, redo them of course, as Netlist suggested.
-Chris
Old 14th September 2004, 10:51 AM   #8
Bazi is offline Bazi  Denmark
Hello Calebay
If you stil need a schematic for your Luxman L 100
I got one ! ;o)
And the bedst part.... it´s in Denmark
Bazi
Old 16th September 2004, 07:36 PM   #9
mikeks is offline mikeks  United Kingdom
Account Disabled
Hi bazi...send moi copy please...
Cheers.
Luxman L-100 Schematic neededHide this!Advertise here!
Luxman M02 Schematic? audiopro Solid State 5 11th December 2008 08:30 PM
Luxman A-471-Schematic ROVSING Solid State 5 3rd November 2008 10:45 AM
Luxman LV-102 schematic. daddario Solid State 0 17th September 2008 11:24 PM
Luxman L-215 integrated amp help needed gaborbela Analogue Source 1 23rd August 2007 05:23 AM
Copyright ©1999-2017 diyAudio
