Opto Couplers - diyAudio
Old 4th June 2002, 02:05 PM   #1
blu_line's Avatar
Default Opto Couplers
I like to isolate my bitstream converter (TDA1307) with opto couplers from the DAC (TDA1547).
Has any one ideas/links/circuits and suggested components ??
grtz
Simon
Old 4th June 2002, 02:57 PM   #2
Send a message via AIM to BeanZ
The HCPL-2232 and the rest of this HCPL series is an awesome high speed optocoupler for high speed digital applications. This is and Agilent (HP) part but I think that it may be syndicated by other manufacturers. You will probably need some driver circuit with most optocouplers including this series. This part is available through digikey and www.digikey.com.
BeanZ
BeanZ
Old 4th June 2002, 03:00 PM   #3
tiroth is offline tiroth  United States
Jitter is sure to increase. I would use a series resistor instead...this presents some impedance to high speed switching currents without affecting the signal much.
What do you hope to obtain through the use of the optocoupler?
Old 4th June 2002, 03:18 PM   #4
Jitter shouldn't increase much at all as long as you use proper grounding techniques and drive on both sides of the coupler. Also you may want to check out the ISO150 from Burr-Brown (TI). It is designed for this type of thing and they have similar applications. Optocoupling the signal ensures complete isolation of the analog and digital circuitry. Though that is not to say that noise can be coupled between them with poor design.
BeanZ
BeanZ
Old 4th June 2002, 06:15 PM   #5
blu_line's Avatar
thanks i will check them out.
I have spoken to the former designer of the DAC7 (TDA1547)
and he stated that opto couplers are one of the solutions to get
a good design with both the TDA1307 and TDA1547.
grtz
Simon
Old 5th June 2002, 12:38 AM   #6
alvaius is offline alvaius  Canada
Optocouplers tend to be quite jittery... just like a TOSLINK connection which is essentially an optocoupler. The ADuM1100 is based on different technology and tends to be much better.
However, limiting edge speed, and excellent layout are likely to accomplish what you are trying to do. That is my opinion and others will no doubt differ.
baby Karlson couplers freddi Full Range 42 11th July 2013 10:51 PM
18" Karlson couplers freddi Multi-Way 0 24th November 2007 02:11 PM
Karlson couplers - who is foolhardy enough to try them? freddi Multi-Way 21 21st January 2007 02:48 PM
Looking for opto-couplers for Onkyo DX 6990 petit_gars Digital Source 0 16th July 2005 01:01 PM
fast opto couplers/isolators blu_line Digital Source 2 24th March 2004 09:43 PM
Copyright 1999-2017 diyAudio
