Circlotron amp using N-channel mosfets - Page 10 - diyAudio
Old 19th April 2004, 02:04 PM   #91
mgreene is offline mgreene  United States
Default "is it same as Mr Circlotron's."
I was interested in the details of the tube driver stage.
Is anyone considering using a battery PS on the output stage of such an amp?
Also, how does the design being discussed here relate to Tenor's solid state amp - if at all?
Mike
Old 28th June 2004, 02:43 PM   #92
Circlotron's Avatar
Different in detail but exactly the same principle.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 11th May 2011, 11:09 PM   #93
tiefbassuebertr's Avatar
I am looking for a bias servo appropriate for CSPP/Circlotron power buffer.
For Totem pole output stages there exist a topology designed by William T Chater. By post #40 about
Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power?
you will find more informations.
About
Bias control for power amplifiers
is to find the circuit idea therefore.
Is it possible to perform a conversion of this topology suited for a Circlotron ?
Old 23rd August 2014, 07:16 PM   #94
Originally Posted by Circlotron View Post
Hi everybody. This is how the project is progressing. As you can see I have made the output into a Sziklai pair on the suggestion of AKSA, (thanks heaps, mate ). This makes the output LOTS more linear. As an example, before I had to use ~200mA quiescent current to eliminate crossover distortion, now I can do it with 75mA. Actually I am running 100mA right now and may return to 200 and see if it sounds and better.
The fets are now tricked into thinking they are P-channel devices and so the whole circuit is upside down. It looks a bit confusing at first, but take my word for it, the things works. To me it sounds just so smooth and clean. Even through that 3C90-cored input tranny!
Next thing to do is figure out some feedback from output to input because the output impedance is 0.47 ohms courtesy of the "source" resistors (that are connected to the drains).
I have not cranked the volume way up yet because of lack of drive voltage avaliable. I gotta make a preamp for it yet. Doesn't that symmetry of the schematic make your mouth water?
GP.
HI
It is a CFP circlotron ?
http://www.diyaudio.com/forums/attac...on-18-6-02.gif
Who made a solid state circlotron ?
Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? tiefbassuebertr Solid State 49 19th April 2016 04:18 PM
Replacement transistors/mosFETs for holton n-channel amp hulsebos Solid State 24 12th March 2010 05:56 AM
Push-Pull using only N-Channel MOSFETs Kashmire Solid State 32 6th August 2009 02:48 PM
Circlotron djk Pass Labs 13 20th August 2006 04:19 AM
P-channel mosfets for Aleph Peter Daniel Pass Labs 10 16th August 2002 12:12 AM
Copyright ©1999-2017 diyAudio
