Another way of making the output section with class A predriver
Old 5th August 2004, 09:04 PM   #11
Konrad is offline Konrad  Norway
Is'nt this just a current loaded buffer, maybee also a current loaded VAS stage before this ? The mpsa 13 the current limiting transistor for the active load. Probably its class A. 1,1-1,2v ube. near 12 mA in tr23 There is many ways to achive class A and this is just one of many for many different stages. As such it dont seem to have any (significant) advantage over other commonly used low open loop gain/low lockal feedback in the output stage.
BUT : if the current limiting transistor also has temperature feedback as it will. And the overall dc performance is achieved thru overall feedback, but is most definetly coupled thru temprature. But then it will alter the biaspoint also for the innput stage as temperature alters. If class A is the goal there will still bee 'small' changes. ie sin tone to full output at klass A settup load the temp in the output stage would make a small drop (for most commonly designed class A stages). And again altering the reference bias point for the input stage, as balance is concerned dependent the rest of circuit. For the buffered stage altering the constant load and for the output stage the bias is altered. Hopefully this is most elegantly designed and stable, this is werry hard to achieve and i sertainly dont tink it is possible under all the varius loads and enviroment.
Another way of making the output section with class A predriverHide this!Advertise here!
making 25w constant class A amp space2000 Solid State 25 1st September 2008 05:07 AM
Output section on preamp questions/breakdown. kegger Tubes / Valves 6 6th December 2006 12:54 AM
Making of Lightforce 1 Class D Powerbriefcase Lars Clausen Class D 66 30th October 2006 11:46 PM
Output section impedance change query KBK Tubes / Valves 7 5th August 2006 01:47 AM
marantz da-12 and cd 7 output section please? lt cdr data Digital Source 1 20th May 2005 11:03 PM
