High power Amp with OPA445
Old 2nd August 2004, 11:07 PM   #1
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
Default High power Amp with OPA445
what the parts i need to put in the pic......that it will realy work.
and how mach power is with 35V + -...
thanks....
tamir
Old 3rd August 2004, 10:57 PM   #2
Account Disabled
what worng?!
Old 4th August 2004, 11:26 PM   #3
cunningham is offline cunningham  United States
Looking at the picture, I guess that the op-amp has a VAS stage as the output from it, and then drives a 'similar to' darlington output EF stage. The drivers appear to be biased by a current source, I think this could work.
Old 5th August 2004, 07:52 PM   #4
Account Disabled
it is need to work !! it is have to be...!! it is from the compeny of the opaamp.
but my Q is.... what kinds of transistors i need to connect to get him work....
and how much power that is?
thanks
tamir
Old 5th August 2004, 10:09 PM   #5
Q3 & Q4 could be darlington drivers, Q2 is bias servo, and should be comparable in beta (Hfe) to be mounted with outputs for thermal stability. Make sure that the transistors you select have a breakdown Vce of at least 100V. I would say you may realistically get 90-100W RMS!
Q1 is an emitter follower, and has no voltage gain...but has a current gain. Rb should be a potentiometer(maybe 47K), and Rt (4.7K) might work, if servo is a darlington type device. As Q2 saturates it turns off the output bias. Turning Q2 off some will allow the outputs to bias class AB and also be linear as far as temp. coefficient.
I would use a current source\current mirror circuit for Ibias as it is more accurate.
Include negative feedback just like any other op-amp circuit, and referenced to ground(0V).
Get a cross reference book to determain the type of devices you may want to use for drivers and outputs. This dosen't look to complex, Good Luck!
Old 6th August 2004, 02:41 AM   #6
Account Disabled
thanks u !
buy how kind i need to use for the darlingtons.......
High power Amp with OPA445Hide this!Advertise here!
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
need replacement part opa445 opa551 opa552 prorms Solid State 0 28th October 2008 10:08 PM
Is a OPA445 AC stable with 100% Cap feedback at HF? Fanuc Solid State 0 30th July 2007 09:07 PM
Copyright ©1999-2017 diyAudio
