I am thinking of using balanced lines to connect my monoblocks as the sound is supposed to be better (noise/rf rejection etc)
Does anyone know of a good kit(ie not madly expensive and difficult) to use. I am limited to kits at the moment as I am still a learner! Are the White Noise Audio Kits any good? Someone also sugested optical! Whats involved in that setup? Is it better?
'I have nothing. I owe much. The rest I leave to the poor. - Francois Rabelais satirist & doctor d.1553 |
#2 |
Good morning world, good morning sunshine, good morning...........anyone there?
#3 |
One of the main problems with using optical coupling for quality analogue audio is that the required devices lack linearity.
A simpler and cheaper alternative to balanced might be to use a pre-amp that can drive the cables with a much larger signal than the power amp requires and then attenuate the signal at the power amp end, this would reduce cable induced noise by the same factor. |
#4 |
Anyone here use Rods Kit 88 preamp?
Is it any good? If so I could use that and a balanced line driver for a simple but great sounding pre. Any ideas? Please remember that kits our simple designs are best at the moment. I'll be getting some if BrianGT's monoblock GC's soon and these will be my FIRST soldering since leaving school! So for me it really is a case of KISS!!!!
#5 | |
/M
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction |
#6 |
Do you suffer from interference?
I ran a long cable between two rooms at home, and I used ballanced connections. The circuit was such that if one of the outputs was missing, the gain of the other increased, to maintain the same signal level. I had a problem with the cable, so I arranged one channel as a single ended output by shorting one side. There was no difference in the noise, which was low anyway, between balanced and single ended channels. In other words, it's probably not necessary to use a ballanced connection. |
| Logitech Balancing | troy310589 | Parts | 0 | 15th March 2007 09:58 AM |
| balancing speakers | JohnST | Multi-Way | 3 | 19th July 2004 10:42 AM |
| Balancing | Raka | Analogue Source | 6 | 18th April 2004 06:04 AM |
| Balancing a 3 way | VictorG | Multi-Way | 5 | 29th October 2003 01:41 PM |
| Balancing PP output - which? | lgo51 | Tubes / Valves | 15 | 4th July 2002 03:35 AM |
| Page generated in 0.08944 seconds (76.97% PHP - 23.03% MySQL) with 10 queries |
