Old 3rd June 2002, 02:15 PM   #11
paulb is offline paulb  Canada
Now we're cooking.
Altaic, do you have any other requirements like power output, etc.? Cost, efficiency, and complexity are other tradeoffs. And finally, how much experience do you have building electronics stuff?
For example, one of the simplest amps to build is the Son of Zen, except it requires a beefy power supply. That and the heatsinks probably dominate the cost (as peranders said).
My Bwahahaha meant that it will always cost more than you think it will. You may want to start hunting up surplus shops in your area.
Old 3rd June 2002, 02:57 PM   #12
Hi Altaic,
The nice thing about DIY is that you can build something that you can't buy in a shop. Commercial stuff is allmost allways the cheaper option. But if you want something special, you gonna have to build it yourself: enter DIY audio.
For example: Class A commercial products are very expensive: Enter the JLH 10 Watt Class A amp, the Pass ZEN amp, the Elliots DOZ amp, The hiraga Monster amp, the MJ amp, Pass A40 amp etc.
Another example: 400 watt in 8 ohm... hmmm Aussieamps .. don't remember then name correctly, he sells PBC boards, the Leach amp.
make a list of these and select the one that fits your needs without being overly costly ..bwahahaha
goodluck,
Thijs
Old 3rd June 2002, 09:55 PM   #13
I've got a fair amount of electronics experience. Recently, I had to solder some new capacitors (and a few other little things) on my overclocked Athalon motherboard. The old ones blew up.
It's amazing how resilient "delicate" computer components are.
I first found out about Elliot's 60-100W amp (project 3A), and I thought it might be fun. But since then I've been learning about new "fancy" amp technologies... I'm now thinking of looking for a switching design, or as JoeBob suggested a Class-D or Class-T. I've heard of Class-Js, too, but I'm not sure what their deal is.
Thanks a bunch for the help!
Will
Old 4th June 2002, 03:06 AM   #14
Altaic, can I just ask why you want such a high power amp? It's a common misconception that "more" is better in audio. Unless you are seriously going to raid junk markets, I think you will have a great deal of difficulty in producing a very good sounding 500W amp within that budget. Most people seriously overstate the amount of power they need, for all but the most absurdly inefficient speakers 100W is more than enough for a typical domestic situation. Of course everyone is different but to give you an example, I have a 100W amp and have never, and I do mean NEVER, got it anywhere near maximum power, indeed it would typically run at no more than a few watts (remember it's not a linear scale).
In terms of "bang for your buck" I believe that you would be far happier with the end result if you looked at amps up to the 100W mark. You should be able to produce a very good sounding amp within that budget.
Hope this helps.
Pete
Old 4th June 2002, 03:28 AM   #15
Samuel:
I was referring to the amp designs at http://www.aussieamplifiers.com.
Will
Old 4th June 2002, 03:43 AM   #16
Pete:
Thanks for the advice. I don't specifically need a 400W or 500W amp, but they are more interesting to build than <100W ones. Also, I can use cheap parts if I only want to use, say, 150W of the design's spec. But I like flexibility, and I may actually need high power in the not-so-distant future (not for a home stereo system).
Will
TX9 Comparison dirtyk777 Subwoofers 0 15th March 2007 03:57 AM
DIY Comparison marcus555dc Subwoofers 0 21st February 2006 12:05 AM
tw comparison ermes Multi-Way 0 29th March 2004 12:32 PM
AB comparison Raka Chip Amps 124 27th June 2003 09:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
