Old 29th July 2004, 02:50 AM   #1
extremy is offline extremy  United States
Default Replace a transistor or trashcan,
I bought a used KLH sub with a blown power transistor. I plan to fish out the broke transistor and replace it. I don't see any other obvious problems, but are there other components that would have been affected by blowing a power transistor on a subwoofer amp? The sub itself still works. I have no problem doing any repair of this level.
I'm not sure how bad KLH is, and I really bought this for practice.
If KLH is really worthless then maybe the amp needs to go in the trashcan...
Any ideas?
Greg
Old 29th July 2004, 03:24 AM   #2
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
at the very least have a trashcan ready
Old 29th July 2004, 03:43 AM   #3
tenderland's Avatar
Default blown
I would replace the compliment out put xistor
Then using an ohm meter you go back to the driver xistors and check them. Also do resistance check on all the resistors near the output section especialy the lower ohmic values. and check large emiter resistor connected to the output xistors
An ohm meter can be youre friend
Jeff
Old 30th July 2004, 12:05 AM   #4
It depends on the circuit topology. You may want to check the driver transistors also.
I don't know much about KLH amps, but I have a couple of KLH 15" 4-way speakers (linear dynamics design) and I love them, they sound great. They are 120W RMS and are 4Ohms. I have almost finished the amplifier design to drive them. Just some minor bugs.
Old 30th July 2004, 12:26 AM   #5
anatech is offline anatech  Canada
anatech's Avatar
You know, you should replace both outputs and drivers. Always one back further than the last blown device.
I guess that means that on a Yamaha amp, you replace the preamp too.
The KLH will sound great on your computer. That's where the last cheap sub I repaired is. My wife loves it!
-Chris
aleph-3 transistor replace space2000 Pass Labs 3 2nd July 2008 07:26 AM
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
replace 5y3 ardan77 Tubes / Valves 5 15th January 2006 03:41 AM
what do I replace...? 9am53 Tubes / Valves 10 5th May 2005 02:20 AM
transistor circuit to replace transformer in ribbon mic? ubertar Instruments and Amps 1 14th August 2004 09:42 AM
Page generated in 0.09760 seconds (72.21% PHP - 27.79% MySQL) with 10 queries
