Irf540 Amplifier
Irf540 Amplifier
Old 29th July 2004, 10:55 AM   #21
Lars Clausen is offline Lars Clausen  Denmark
Has anyone seen any examples of real life IRF 540/9540 amplifiers here on DIYaudio.com? (apart from the ULCA).
I mean amplifiers that are designed to actually work.
Old 29th July 2004, 11:23 AM   #22
tschrama is offline tschrama  Netherlands
I have posted a IRF540/IRF9540 amp, that uses a new idea of employing current mirrors to use both legs of the diff-pair to drive the VA-stage. Should be here somewhere under a topic named 'new idea' or something like that. It is designed to actually work.. If i'm recall correctly, I once posted a IRF540/IRF9540 disign is a topic called 'cheapest amp possible' or somthing like that....that one should also work..
cheers,
Thijs
Old 29th July 2004, 11:40 AM   #23
sajti is online now sajti  Hungary
Check this page: http://users.otenet.gr/~athsam/#Audio_Power
There are two amplifiers with IRF540/9540
sajti
Old 29th July 2004, 12:21 PM   #24
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hey lars we did never see the finished amp i guess it was the .. ULCA2 ...
~3 * 3cm.. ??
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 29th July 2004, 12:29 PM   #25
OliverD is offline OliverD  Germany
OliverD's Avatar
what with this ??
Your output devices have long been obsolete. Don't buy these transistors, you will get fakes. The diode string is the wrong way round.
I have a very simple amplifier for you, which is made from "real" transistors and a opamp input stage. It is a proven, reliable design. It can be scaled up and down as you like...
Click here
Old 1st August 2004, 09:37 AM   #26
SonnyA: You have a really good memory The project is not forgotten, it was the idea of making a good amplifier kit at a really low price. Was the proposed price range some 10$ per ch. in parts?
Now some work has been done with this idea over the past 6 months, and about to overcome the obsticles of high capacitance in the MOSFET's vs. the quest for higher bandwidth. The new idea in the bowl of this project is that you can't successfully forget high performance in the search for low cost. Even if some low cost / low performance solutions has made it over the years.
But why not try to make something better?
The performance has to be there first, and then if the price is reasonable, i think the project has sustainability. That is why the ULCA project is changing into 'high speed / high performance MOSFET amplifier' project instead. Not with so much focus on ULC (Ultra Low Cost), but instead high performance using these incredibly rugged and potentially fast IRF output devices.
To get open and airy reproduction of treble, the ULCA is now turning into a 'ultra wide bandwidth' amplifier combining some of the features described in the ULCA thread. Bandwidth as high as 500.000 Hz (-3dB) is now possible, and fully stable.
Also i think limiting the output power to 50W/100W of the small output devices, is a drawback, so the circuit and PCB in it's new version also allows for use of bigger output devices. Power of 100W/200W is now very easy.
Of course the size of the PCB is now slightly bigger, and also the price also higher than the 10$ per ch. first proposed.
I know to get really high power in a small space, and the highest quality, there is today (IMHO) no way to get around PWM. The state of the art is Class D. But analog amplifiers can still have a place, as they are simple, cheap and fun to play with. And still can give you great performance, at the cost of potent power supplies and nice big heat sinks.
ULCA
Old 1st August 2004, 10:09 AM   #27
Upupa Epops is offline Upupa Epops  Czech Republic
Guys, who will send me private mail, get from me schematic of amp with 540 / 9540 - I havn't own pages .
Old 2nd August 2004, 07:52 PM   #28
sonnya's Avatar
Nice to hear lars.
Maybe we should meet/or talk in the phone..
I agree with you that if we want a good performance we need a little more. But still it should be possible to make a "VW beetle" amp for everyone at resonable price with a good performance...
Maybe not look so much on what is "latin" regarding parts to use. But design an amp with the right parts to get the right performance..
Maybe it should be more like a 3 - 400DKK per channel amp?
Maybe make a joint design?
Old 5th August 2004, 06:43 PM   #29
consort_ee_um is offline consort_ee_um  United Kingdom
The problem with the IRF540 is the relatively high gate drive voltage required at high output currents. You need a gate drive supply 8V beyond the supply rails. Or you end up with an inefficiently used power supply i.e +/-40V supplies to get a +/-30V output swing.
The classic way around this problem is bootstrapping the drive voltage. I have only seen it done to the upper transistor. If you are using a complementary N/P channel pair you need to bootstrap both power MOSFETs.
Here is the BBW amp. Bootstrap Both Ways. Its cousin the ambiamp swings both ways! Its not as good as the blameless but probably better than the gainclone because of the output stage symmetry. It is based on the 1977 Hitachi application note. I have not got around to building it but it simulates OK
Old 5th August 2004, 09:38 PM   #30
It's realy prehistory of mosfet amp. Why do you see problem with higher rail voltage for driving of mosfets gates ? Use two low voltage ( you have truth, it must be practicaly about 7 - 8 V higher ), low power supply, connected in series with main supply. All cost approximately 3 - 4 pound for one channel. Is eight pound problem for you ?
Irf540 AmplifierHide this!Advertise here!
IRF540 Amplifier Ermac Solid State 10 1st November 2009 01:21 AM
On IRF540/9540 Hans Olofsson Solid State 40 21st October 2007 07:00 PM
Irf540 ANTHONY2181 Swap Meet 0 15th August 2002 04:39 PM
