Hello. I realize this is kinda off forum topic. But I figure this is the best forum of all the one I know to ask. I am betting the some people in this particular forum have exerpience with this.
Wondering how to extend the battery (and thus uptime) of a UPS. There are some expensive models with external expansion battery packs. Could I take a more reasonably priced UPS, operate a little, and just hook up a huge honkin' external battery in parallel with the internal one? Or perhaps replace the internal one (or two) with the external one (or two)? Not sure what issues may come with having lead acid sealed gell batteries in parallel. Or how this might impact the internal battery charger. Thanks a lot for any information! |
#2 |
I've done this myself with a UPS that used two 7 Ah gel cells in series for my home entertainment system. I installed external 17.5 Ah batteries with a quick disconnect inline cable connector designed for high current battery applications.
Because voltage drop in the battery lines can be high due to the large current draw, extend the battery connections only as long as really necessary to reach the external battery and use only an external battery(ies). Using heavier gauge wire won't hurt either. A gel-cell of several times the AH capacity can still be adequately re-charged by the UPS circuit but it will just take that much longer after a use. The thing to worry about more is how well the UPS is designed for duty cycle. A manufacturer making a UPS that is designed to hold a computer up for only as long as it takes to shut it down properly isn't going to build cooling features into their design to allow the UPS to deliver it's max rated output power for an hour or more. You may need to operate the modified UPS with the cover removed and a muffin fan blowing on the power transistor package or/and also power transformer inside to get longer service time under load. You also may need to reduce the max load you expect to keep running on battery backup for a given rated UPS being used for longer backup periods.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#3 |
Hey. Thanks for the reply! Yeah, I intended to use heavy guage and keep it close. Had not considered the long term thermal aspect. I should only be using roughly half the wattage (not VA) the unit I have in mind is rated for. So hopefully it shouldn't be too big a deal. What about the charger though. Wouldn't it also be designed with a specific charge time in mind? It might not like having to spend 10x as much time charging.
Do you know what would happen if you paralleled batteries? There might be an issue until the voltages were equalized. Perhaps put a power resistor between them for equalization to limit the current. Then connected straight parallel, they could be charged and drained in unison. Maybe? Or if reverse current through the battery with the lower potential is a problem, perhaps run the UPS off each battery set one at a time and disconnect when reaching a specific voltage. I just hate to waste the batteries in the UPS. |
#4 |
You may be thinking too much. Off the top of my head, as long as the charging circuitry can handle the required current (especially at initial charging if starting with low batteries the first time) just wire it up for direct parallel with fat wires and it should be OK. the voltages should all drop at the same time...
...I don't *think* I'm missing something here...
Jesus loves you. |
#5 |
Many of the cheaper units have calculated battery power such
that the batteries run out before the unit overheats. |
#6 |
Perhaps some forced cooling would be the solution as rcavictim suggested. I have some super quiet 80mm fans from the computer world. Maybe I can even figure out how to get it to switch on only when operating on battery.
#7 |
If the batteries have different aamp hours, they would have different internal impeadences. Hope this doesn't effect the operation and charges one battery from the other, it may get hot.
you may want to add a impeadence matching resistor on both batteries, so the percent difference is not to great. small Ohm-age though. |
#8 |
Still, if this stuff is for-cheap-or-for-free, wire it up and see what happens. keep a hand on the charger if it doesn't blow up right away and if it gets warm unplug and return to the drawing board.
Jesus loves you. |
#9 |
If the batteries are always under a charge or discharge, then they can be parralled up as needed. But if they are expected to sit for extended time unused, the one weakest one will siphon off the charge of the whole bank unless they are perfectly matched.
#10 |
hopefully it a older ups. the new ones with smart charging go all
stupid when you mess with the batterys. thay read under charged or over charged or turn off when the bettery is good and full one ups that would work is a old rack mount u can put a big honkin battery on that. i am soon ill post a pic of mine so you can see it could handle it. wires and all you can put bigger batterys on the small ones but there not made to run that long. and likelly will die when you need it most heres one lets have a boo inside |
| Extending Capitor Leads | jdubs | Parts | 2 | 28th April 2007 04:41 PM |
| Extending a DSP card | meta | Digital Source | 0 | 7th December 2002 05:50 PM |
| Page generated in 0.10692 seconds (79.11% PHP - 20.89% MySQL) with 11 queries |
