#21 |
See Geoff's links.
Grey |
#22 |
Nelson and Grey,
Well, I have to admit that I've been wrong. I was hoping that someone here could give an explanation, rather than just telling me the way that it is, but I understand if you don't have the time. Let me explain it to those that I've possibly led astray. A surface between two mediums is a radiation filter. What this means is that it will reflect radiation or transmit radiation through the surface, depending on its properties (see Geoff's list). Some materials are better than others, etc. What is important to understand though (and what I was having trouble with) is the fact that the filter is the same for both directions. For example, a shiny object that reflects radiation away from it, also reflects internal radiation back into it. Let me try a picture: ....Heat...................| >>>>>>>>>>>>>>>>|>>>>>> .............................| transmitted heat .............................| .............<<<<<<<<<| ..........reflected heat| .............................| .............................| ........ Medium 1.......| Medium 2 Heat coming in from the other direction will transmit and reflect to exactly the same proportions. This is important, because otherwise the laws of thermodynamics will not be conserved. Otherwise, one could imagine a surface that had perfect transmittance one direction and perfect reflection the other. This fictional paint would cause objects to begin heading towards absolute zero, or become infinitely hot. Obviously this is not the case. If you are having trouble with a heat sink that is a little too small, you may try painting it black before giving up. It may make the difference. As far as chroming: I have to admit that it would look cool. Even though it would be a litttle warmer than a black one. Standing corrected, Dan |
#23 |
The one and only
A very lucid explanation, and a gracious concession.
#24 |
From an old IERC catalogue.
<i>Black anodize provides a 8-10% increase is heat dissipation over unplated Aluminium under most condition of natural convection.</i> Regards James |
| What might this mean for heat-sinks? | seventenths | Everything Else | 17 | 1st July 2008 07:20 PM |
| FS: Heat sinks | gengis | Swap Meet | 8 | 17th March 2006 01:27 AM |
| Heat Sinks | serengetiplains | Parts | 3 | 3rd January 2006 06:41 AM |
| where do you get your heat sinks ? | percy | Chip Amps | 12 | 16th August 2005 07:00 PM |
| Page generated in 0.09289 seconds (76.40% PHP - 23.60% MySQL) with 10 queries |
