What is a darlington output exactly?
Old 17th July 2004, 08:55 PM   #1
mjarve is offline mjarve  United States
mjarve's Avatar
Send a message via AIM to mjarve
Question What is a darlington output exactly?
I have seen the term darlington output used in several instances regarding the output stages of an amplifier and I never quite understood what the difference was with a "standard" output stage. Do all darlington outputs use the (in)famous Darlington Power Packs (STK-0040 - 0050, etc.)?
Please pardon my ignorance on the issue.
/Mike
Old 17th July 2004, 09:06 PM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Hi
Darlington Output refers to that two output devices are coupled close together, - output from the first device to the Base/Gate of the second device, as seen on most power amps.
This is quite common, and can be made by using two devices (a driver and an output device) or a single Darlington device (which contains two devices in one package)
Furthermore there are the "Three Darlington Output Circuit", which I*m very fond of my self. This TDD uses three devices; a predriver, a driver and the output device
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 17th July 2004, 09:16 PM   #3
mjarve's Avatar
Thank you. That was just one of those things that has been sitting around in the back of my mind for years.
/Mike
Old 17th July 2004, 09:20 PM   #4
cunningham is offline cunningham  United States
Darlingon connected BJT's usually come in integrated packages. The transisors inside are matched precisely to have an overall charactoristic whether it be high gain, linear operation. If you use darlington connection with unmatched nonsimilar type transistors in a class AB operation, you are going to have problems... you may have problems anyway...better match them up.
Old 18th July 2004, 02:28 AM   #5
Easyamp is offline Easyamp
Easyamp's Avatar
Darlington
File Type: gif darlington.gif (582 Bytes, 93 views)
What is a darlington output exactly?Hide this!Advertise here!
Replacing a standard output transistor with a Darlington EchoWars Solid State 9 25th January 2008 03:12 PM
LM4702 triple darlington output alexcd Chip Amps 24 16th June 2006 04:10 PM
sziklai-darlington diamond buffer (SDDB) for power output stages mtlin12 Solid State 5 1st April 2005 07:55 AM
Darlington and Triple darlington lumanauw Solid State 78 1st December 2004 01:57 AM
