Old 19th July 2004, 09:07 PM   #31
Paulmc, I understand your diagram very well and it is exactly this arrangement I have been refering to all along.
Clearly for pure DC anything less than +/- 1V cannot pass through but we're not really talking about DC, the only way of seeing DC on an AC waveform is by integrating it.
The point I'm trying to make is that if you apply AC with an offset (the reality), this diode arrangement won't have much effect except for reducing the ampitude of both halves of the waveform by two diode drops, it can't possibly remove the offset because the diodes directly couple the input to the output.
Old 20th July 2004, 01:51 AM   #32
Account Disabled
an A/C with offset is the same as a DC + A/c with no offset.
The cap will function the same in either situation. and diode really doesn't do anything here in terms of removing A/C.
Old 20th July 2004, 09:11 AM   #33
Paulmc seems to be thinking of simple DC rather than DC which is riding on the back of much larger AC.
The key components in a DC blocker are the capacitors which should be large so that they present a low impedance at mains frequencies, the diodes should rarely conduct if at all.
The claims for the Humbuster state that it's the diodes that remove the DC and this is what puzzled me about it. The capacitors appear to be several thousand times too small to be effective.
Old 20th July 2004, 06:47 PM   #34
Hi!
I also thought that the caps are the key components and the diodes are used to clamp the max voltage across the cap.
...which is in heavy mismatch to the statement of paulmc...
On the other hand paulmc gave the technical details of his product
and tried to convey how it works. His behaviour does not look like someone who sells expensive but effectless circuits...
Hm, do we miss out something?
..may be some interaction with the nonlinear inductive
transformer load...?
Anybody out there who tried it?
My mains supply has nearly no Offset, so I cannot test it (less than 5mV, measured behind a passive filter of 200k and 5x10uF MKT, which reduces the AC component to some millivolts and overdrive of DMM is no issue)....
My two fat 1kVA torroids make some noise, not matter if I put 100.000 uF in series or not. Their noise is definitely not related to DC saturation.....
Bye
Markus
Old 22nd July 2004, 04:24 AM   #35
SmarmyDog's Avatar
Perhaps the brief dead time that occurs during the zero-crossing when no diodes are conducting is long enough in duration to allow the core to reset (or at least get much closer to resetting) so that any cumulative bias is reduced or eliminated. Using two diode drops could be the minimum dead-band for a noticeable improvement.
Yes, it is quite possible I have no idea what I just said, but I’m gonna stick my name under it anyway…
-Casey Walsh
Old 19th October 2008, 05:17 PM   #36
klonius is offline klonius  Croatia
Default PS AUDIO Humbuster
Does anyone have a full schematic for diy humbuster?
Old 1st October 2010, 04:21 AM   #37
Ulisez is offline Ulisez  Mexico
Yep that would be great.
Old 1st October 2010, 06:36 AM   #38
Mooly's Avatar
They all use the same technique... project here
Mains DC and Transformers
A simulation free zone. Design it, build it, test it.
Old 22nd April 2011, 12:29 PM   #39
CCD is offline CCD
Hello All.
@ paulmc
you have Schematics?
CCD
Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? tiefbassuebertr Solid State 43 22nd January 2012 12:50 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
Looking for analog audio circuit designers and audio researchers cnotley Everything Else 1 29th September 2008 09:04 PM
Question about DIY 'Humbuster' schematic Glowbug Power Supplies 8 14th March 2006 03:57 AM
Page generated in 0.10672 seconds (79.31% PHP - 20.69% MySQL) with 11 queries
