DC-protector for Leach Super amp
Old 27th May 2002, 11:57 PM   #1
supernet is online now supernet  Europe
supernet's Avatar
Question DC-protector for Leach Super amp
Does Leach Super amp need any DC protecting circuit with relays at the output, or it already has his own protection?
Thanks for answer.
Old 28th May 2002, 05:38 AM   #2
BeanZ is offline BeanZ
Send a message via AIM to BeanZ
The Leach SuperAmp has 100% feedback at DC. This means that a constant DC voltage cannot appear at the output. If you mean turn on pops and clicks, it is never a bad idea to protect against those. My stereo Leach SuperAmp does not incorporate relays and has no DC offset problems.
BeanZ
Old 28th May 2002, 12:26 PM   #3
djk is offline djk
djk's Avatar
A new car needs neither a jack nor a spare tire. 10 years down the road you will find out that the tiny lug nut wrench won't remove the now rusted nuts and the now rusted jack won't lift the vehicle and the space saver spare will only get you to the nearest tire store at 20 miles an hour (if you remembered to check the air once a month for the last 10 years). The foldback current limiter in the Leach will protect the amp from short circuits when it is new. A relay will keep it quiet as it ages, and a crowbar will protect the speakers if it blows up. I own a professional power amp that has two stage inrush current limiting, foldback current limiting, a clipping limiter, a speaker relay, and a crowbar. While it costed twice as much as other amps with the same power, is cheaper brothers have been in the landfill for quite a while now. With a few mods it even sounds good! The Leach amps sound great, being a DIY project the other details are up to you.
Old 28th May 2002, 03:57 PM   #4
supernet's Avatar
OK, thanks for answer
If I decide to go for protection circuit, would be OK to use a kit K4700 from Velleman. It has a delay and some kind of DC protection with op amp. But could I use this circuit for my dual mono design.( one transformer with separate secondaries for each channel)?
Old 28th May 2002, 04:11 PM   #5
chris ma is offline chris ma  Canada
chris ma's Avatar
Default K4700
Hi Supernet,
I am in the exact situation as you are. But I've bought two K4700 kits with the intension to leave one channel DC proctect not connected for each kit. I am building the JLH for ESL mono blocks the soft start feature of the kit would have to be in two locations anyway. I don't understand how you can connect it(one kit) to two mono blocks anyway.
Chris
Old 28th May 2002, 04:14 PM   #6
chris ma's Avatar
Sorry,
Now I understand, you mean dual mono in a box. Yes I think you can use the one kit with no problem
Old 28th May 2002, 06:05 PM   #7
supernet's Avatar
Tell me what is the power and voltage rating of relays. I got one small toroid transformer ( 12 Volts. 20VA) to power mains relay and some LED diodes, because I would like to power K4700 kit with this transformer.
Bye, Supernet
Old 28th May 2002, 06:47 PM   #8
fcel is offline fcel  United States
I think the K4700 kit has it's own power supply.
Old 28th May 2002, 06:57 PM   #9
chris ma's Avatar
The kit comes with its own LEDs and a small transformer. The PCB is about 2X5 inches. Everything is mount on the PCB. One LED shows error(DC detected) one shows soft start and complete.
Chris.
DC-protector for Leach Super ampHide this!Advertise here!
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 03:15 PM
Leach Super Amp HELP ... Ahmad_tbp Solid State 22 28th December 2009 06:44 AM
leach super amp with +/- 78V lenti Solid State 1 21st July 2002 04:00 PM
I need some help with super Leach amp! supernet Solid State 5 22nd April 2002 10:27 PM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 11:16 PM
