#11 | |
At least Halcro, Lavardin and me use CFP in the input diff amp. I have also seen other amp circuits from what I remember. If it is not widely used it does not mean that it is not good. If it was so obvious to know what is the best topology in an audio amp then everybody would use the same basis. Fab |
#12 |
diyAudio Moderator Emeritus
I read this somewhere here. Why is that for very low rail voltage (like +/-15V), a differential is better fed with CCS? While for higher rail (like +/-40V), it is ok to use CCS or plain resistor?
FAB, How big is the CFP resistor can be (how low the current minimal in the first transistor)? Smaller than 50uA is OK? |
#13 |
Hi lumanauw, the reason is very simple: the two emitters of
the diffamp have a voltageswing of the middle of both inputs, that means nearly exact the inputvoltage (plus some harmonics) for a voltageswing of 0.7v at voltagerail 15v, this means that the current fed into the diffamp differs about 4.6%. The higher the voltagerail, the less this effect. At some voltage the plain resistor can give a better constant current then a ccs. I finished my amp this night, but this late in the night i was not able to make extensive listeningtests. But i can say, that i'm very impressed by the quality. The sound is crystalclear and clean, and the instrumentseparation is a dream. Also it's like you can see/feel the singer. (I tested with "brother in arms") (hmm, i hate monolistening) And no sign of any hard sound. I used 2K for the CFP-Resistors, the CFP-BJTs are bc556b, the input transistor are sk170. I skipped the currentmirror, to get maximum bandwidth (-3db at ~1mhz Outputdevices are MJL1302A & co. I already hear some noise, but only when pressing the ear directly to the tweeter. It seems that i already have some thermal problems in the diffampstage, the DC drifts ~60mv with a frequency of ~30secs. I still have to investigate this phenomen, maybe the diffamp is not balanced enough. (2.2mA to 2.8 mA) In spice i tested with upto 10k for the CFP-resistors, but the difference in THD was minimal to the 2k. Maybe i will downgrade to 1k, if the thermal drift keeps... Or i reduce the current to the diffamp. I have to recheck the datasheet for the sk170... Mike |
#14 |
Hi, Mike,
Thanks for the explenation. Now back to the sch in post #1. The main idea of this sch is to advoid 2nd harmonic cancelation, so I dont use differential for input stage. But the VAS is forming differential. Will the harmonics be canceled here or not? |
#15 | ||
This is kind of scary but we must know. Finding good sounding is not the same as finding good measurement. Quote:
#16 | |
Unfortunately, I have not preformed a study on the optimal value for that resistor. I use 2k2 value. I think the resistor value depends also on the ratio of first input transistor collector current versus the second transistor collector current. Gerrard Perrot (Lavardin Technology) in his patent 5,635,874 suggests to use 1/4 of second bjt collector current in the first bjt collector current as an example and I believe that he may have performed a thourough analysis and testing to determine this ratio of collector current. I also think that if you use a too small current you may have an increase of noise depending on the input transistor noise characteristic. Fab |
#17 | |
#18 | |
"Some one like music and some one like distortion" I think "some one like HIFI and some one like distortion" I hate odd harmonics too!
#19 |
Hi lumanauw !
I did some checkings on VAS with Spice, it seems that the VAS mainly creates 2nd harmonics, but i don't know if this is still so if the transistors are matched. Cascoding the VAS had a very big increase in qualitity. I will check with the ccs to the diffamp this evening, but from my imagination, using a resistor with low voltagerails should create 2nd harmonics. (but maybe only with asymetrical topology) BTW, i did some extensive listeningtests with my CFP-testamp, and i must say: Wow, CFP rulez ! is it really patented ? Of course it's still preferable to find a topology for ClassAB that cancels out odd harmonics. Mike |
#20 | |
sensitive to them. I experimented a little, add 3% 3rd harmonic to music (done with software), and you instantly puke, add 3% 2nd harmonic, and you wonder if there really is a difference ! (Okay, played only through pcspeakers) But this means that simple THD-measurements are useless to describe the soundquality of an amp. (Not a new discovery at all...) I still don't know what i prefer, HIFI (ultraprecise reproduction), or some nice harmonics... I am still on the quest to a ultraprecise ClassAB. (Maybe found it last night) I think i "simply" need to construct a single ended ClassA, not showing any odd harmonics. (And then compare them) Mike |
| Work Wpp2400 Power Amplifier | SMARTCAT | Class D | 12 | 10th November 2008 05:59 PM |
| Im BAAAACK! Marathon amplifier question, won't work bridged mono! | 240z4u | Car Audio | 11 | 3rd April 2008 03:56 AM |
| What Speakers Work best with the JLH 10W Class A Amplifier | John Biles | Solid State | 9 | 8th August 2005 01:53 PM |
| Audio Work Bench | Mark A. Gulbrandsen | Everything Else | 7 | 9th March 2004 04:47 AM |
| Is this analyzer good for audio work ? | Bernhard | Parts | 0 | 6th December 2003 07:02 PM |
| Page generated in 0.13138 seconds (82.54% PHP - 17.46% MySQL) with 11 queries |
