Quick Q - This Amp Will Work ? (very Smple Amp)
Old 14th July 2004, 11:25 PM   #1
Dj BASS AMP is offline Dj BASS AMP
Account Disabled
Question Quick Q - This Amp Will Work ? (very Smple Amp)
this simple amp will work with no problams?
and if need to change some thing......?! to make him work (if not).
thanks tamir.
Old 14th July 2004, 11:29 PM   #2
markp is offline markp  United States
At the very least change the resistor and cap on the output to ground from 10 ohm/100uF to 4.7 ohm and .1uF.
If it sounds good... it is good!
Old 15th July 2004, 12:57 AM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
It will work, more or less, but since the 2nd op amp ids driving
a follower stage, the output voltage will be slightly less than
that of the op amp, and since the op amp has only +/- 15 volt
rails, you're only going to use maybe 14 volts of the 40 volt
rails on the output stage.
Old 15th July 2004, 04:10 AM   #4
fab is offline fab  Canada
fab's Avatar
-The first unity gain opamp IC1a has no purpose since the 2nd opamp is sufficent. Connect junction of 1k and 10k inputs resistors to pin 5 of NE5532.
- the 1n4148 diodes are not polarized (reversed biased).
- To get a higher output voltage swing (close to 40v) as pointed out by Nelson while using an opamp for input, you must use an output stage with gain. See the following post :
http://www.diyaudio.com/forums/showt...308#post359308 .
But, of course, this referenced circuit uses mosfet power transistors but the principle for gain is the same for bjt (except that the gain value is different).
Fab
Old 15th July 2004, 06:10 AM   #5
Account Disabled
OK Thank i will do this.
so i need to put one more NE5322 for the input to get more gain?!
Fab
i dont understand what u say about the diodes and the out put.
i have to use in 2sc5200/1943.......
thanks tamir
Old 15th July 2004, 01:24 PM   #6
Account Disabled
Fab
hii !
sorry dont look on the last massege....
my new Q' is...: how i build the output with gain? u can make it for me on my design...?! because the pic in the link is not clear and i do not see the difference.....
tamir
Old 15th July 2004, 01:56 PM   #7
sajti is online now sajti  Hungary
Hi DJ,
the output stage with gain something like this:
http://www.diyaudio.com/forums/attac...&postid=236190
sajti
Old 15th July 2004, 02:17 PM   #8
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
a Lynx amp is also based on an opamp inpiut stage...so is the PA600 that I saw sometime around here...do a quick search...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 15th July 2004, 03:25 PM   #9
fab's Avatar
Originally posted by Dj BASS AMP
hii !
tamir
Dj,
You can refer to sajti posted circuit for output stage with gain -especially if you want to use BJT output transistors instead of mosfets.
Good luck
Fab
Old 15th July 2004, 05:25 PM   #10
Account Disabled
soo..... it is make the amp more complicated.....
OK thanks to All.
Tamir
Quick Q - This Amp Will Work ? (very Smple Amp)Hide this!Advertise here!
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Quick Qs about box construction GhettoSQ Subwoofers 5 8th July 2006 11:17 PM
some quick help PLS v1d9uy Multi-Way 4 11th January 2006 05:18 PM
Just a quick Q VictorG Tubes / Valves 1 19th January 2004 03:15 PM
Copyright ©1999-2017 diyAudio
